2025 Maverick Factory Tri Fold leaking
So should I take it in for a fix? It cost me enough...
post pics of yours that closely match hot runr guy's pics in post 11.
it probably will need a bit of additional weatherstripping installed.
GarryB
GarryB
I'll do it later... I'm being told to do some work... 😆
I wish they would have made the BakFlip MX4 about 1/2" longer, it's hard to get a good seal on both the front and tailgate. With my Elevate TS rails adding a little height, I added a strip of weatherstripping on the tailgate.
HRG
Thanks for the pictures "HRG"
Until I saw them, I hadn't realized that the bakflip set above the tailgate that much.😯
Looks like you've got a good seal now.👍
Good Pictures make a difference.
dusty1787
Dustin
Wisconsin
2023 Maverick EB Lariat
Hey all,
My Mav is about 3 weeks new and I noticed a big water leak where the edge of the seal meets the tail gate. Is this normal? It's a Ford factory trifold install. I'm not talking about some dripping, I'm taking about a significant amount of water penetrating into the box.
Anyone else having this problem?
Suggestions?
Thanks
I have the factory hard trifold cover and automated car washes and heavy rains have yielded a slight water leak into the bed. nothing more than a 1 drip wide leak/stream from the corners by the cab, but only at the front most corners. the rest of the bed stays dry. I am surprised at how many people claim 0 leaks with the covers. specifically with the tailgate...as it has a..."big ol' gap" that isnt sealed (vertical gaps where tailgate meets tailights/fender that isnt sealed to the bed). So not getting any water in is surprising to me. I bought some thick seal tape and placed them on the fender/bed (by taillight when tailgate open) and on the inside edges of tailgate so that when closed it seals that gap up.
But my factory hard trifold does get a small leak on really heavy rains just at the corners by the cab. My dealership did say you can adjust the brackets for the tonneau covers to help minimize the leaks. They also said that you should do actually adjust them bi yearly/yearly as vibrations/using the cover will allow them to move and not be as secure over time. So they should be adjusted.
But if you are getting a massive leak in, I would find out where it may be leaking from and see if you can adjust the cover more to minimize the leakage and/or get some kind of sealing tape/roll and try and place it around where it is leaking to deter water from getting in.
it's probably because the Gator SFX / Ford soft tri-fold is well designed. It has angled weatherstripping on it that channels water away from the bed, and it fits the bed opening better than the BakFlip MX4.
GarryB
GarryB
Ya It's a pretty big leak. I think I'm just going to take it to the dealer and see if they give me the run-round or just fix it or adjust it accordingly. Thanks
GarryB
GarryB
Ya its a big one at the corner. I'll call the dealer to adjust... Thanks
GarryB
GarryB
Freg what a pain in the butt. I guess it could be a lot worse... Hopefully they don't give me a hard time sikces it's 3- weeks old...
GarryB
GarryB
Here are the pics.
Ford Maverick 2025 Maverick Factory Tri Fold leaking 20250407_145527
Ford Maverick 2025 Maverick Factory Tri Fold leaking 20250407_145559
Here are the pics.
I would just get some adhesive weatherstripping and stick it to the bed in that end piece area. looks like under 3", maybe less than 2". you'll want to clean it with rubbing alcohol to prep for the adhesive strip.
I'd try either a wedge shaped or a d-shaped weatherstrip. you can find both of those (and more) on amazon, at a local hardware store, etc.
GarryB
GarryB
What a pain in the butt. That should be a dealership fix not an Amazon one...
you can try the dealership, but if it's installed correctly it might still leak, then you'll need my suggestion 👍
GarryB
GarryB
Lol I think you're probably right 😢
Steeleye
Scott
Wayne, PA
2025 Maverick XLT AWD
First decent rain last night since getting my Mav in Jan and having significant leaking at the cab end, especially passenger side. Anything adjustable here?
Ford Maverick 2025 Maverick Factory Tri Fold leaking IMG_4759
Ford Maverick 2025 Maverick Factory Tri Fold leaking IMG_4761
Ford Maverick 2025 Maverick Factory Tri Fold leaking IMG_4758
Steeleye
Scott
Wayne, PA
One question I have is how much paint should be showing below back window to front edge of tonneau cover?
