- May 29, 2024
- Central Nevada & Utah
- Maverick XLT Hybrid
- Engine
- 2.5L Hybrid
The hybrid Maverick also has an electric booster heater.
The 2023 manual says hybrid has electric booster heaters.
Electric Booster Heater Operation
The electric booster heater ensures that the passenger compartment can be quickly warmed up when ambient temperatures are low.
It is a heater element made up of ceramic resistors that is mounted in the climate control housing.
It directly heats the airflow into the passenger compartment rapidly in the case of low ambient temperatures.
The current is switched via three electric booster heater relays located in the BJB / BCMC.
Electric booster heater operating parameters:
• Engine is running
• HVAC controls have been switched to the highest temperature setting
• Engine coolant temperature is below approximately 75°C (167°F)
• Ambient air temperature is below approximately 12°C (53.6°F)
• Sufficient generator capacity is available
The electric booster heater is deactivated when an engine coolant temperature of approximately 85°C (185°F) or an ambient air temperature of approximately 15°C (59°F) is exceeded.
Fuses in BJB # 4, 7, 9
