2022 Maverick Hybrid started spontaneously.
The Real Maverick
Jack
Yes, I would imagine the ability to start on its own would be a bit of a safety issue, assuming it's parked inside a garage. Although it could make for a good alibi.....
FWIW....
I have read of this before....
On other makes and models over the years. Rare. But if you and I can do a remote start when we want it, a glitch can do it when we don't.
So yes, under a preponderance of caution do not store paper or oily rags under any car or truck with remote start. I've used cardboard as a drip pan under a 1980's pull start lawnmower, but probably not good to use that under your Maverick.
Damn! That would be catastrophic if that happened during an oil change..
To remote start the truck first has to lock the doors and checks to see if hood is latched securely (in the second latch position). If any door is open and or hood is not completely closed Remote start is terminated.
This is obviously meant to slow down theft of truck. I do not know for sure but expect truck to shut off if possible theft is occuring.
brielee3
Rudy
VA
Mustang
I didn’t get the impression he remote started, vehicles shouldn't spontaneously start under any circumstance.
KevCuRaoi
Kevin
Buffalo, NY
2025 Maverick Hybrid XLT AWD
No, the previous comment was when someone was worried about an unexpected remote start during an oil change.
The OP didn't remote start, but there is a possibility that the original owner had remote starts scheduled on Ford Pass. If the SYNC system was not reset, that could be the cause of the "spontaneous" remote start event w/out keys.
Bobbyleep3
Bobby
Triangle-NC
'23 XLT Hybrid
Maybe one of our MTC experts would know if there is any kind of logging that would have recorded the unexpected event?
He stated that he did not start it. But it is possible that he or the prior owner could possibly have done so. Lots of speculation on possibilities of how and why it could have done so it's more likely that an instructed start occured than a spontaneous self start occured. RE: My wife once said "I think I just started the Red Puppy aka red Maverick What do I DO Now?". I have not left my maverick im "extended accessory mode" so I am unaware of if it's possible for ice to cycle or not in that mode. Would be logical that it could? Truck would not necessarily have to be in ready to drive if programed to do just add 10% to HVB.
Dudley
Doug
Indiana
2003 Grand Cherokee
The hybrid behavior is not the same as the EcoBoost.
A "start" does not require an engine start, unless it is very cold and you have the heater turned on.
For example: a remote start for summertime cooling will run the air conditioner off electricity only for as long as the battery charge is above 30%. Then, it may run for one minute to boost the battery to 40% then shut off the engine. Repeat as needed.
*Normally it will run longer than 1 minute if the engine coolant is cold but not if warm. Warm is greater than 120°F.
Yep. From this thread I learned the Hybrid does have that auto start feature for battery charging while the Ecoboost does not.
But I was referencing the remote start feature only. I assume they are the same for both, which would mean IF it was accidentally by the current owner or as one response said maybe the previous owner, remote started, it would not have run for only 1 minute and shut off. At least I HOPE a hybrid remote start is for longer than a minute.
But, as I mentioned, given the hybrid auto start feature, the current owner needs to find out how to disable that, if it can be, for when it is in his garage. Kinda dangerous!
The Real Maverick
Jack
I'm saying a "remote start" can last for 1 minute, yes. 100% true. There's no reason to run the engine for cooling. Only heating. Or, possibly recharging, which takes 1 minute.
Dudley
Doug
Indiana
2003 Grand Cherokee
So, on a Hybrid, unlike when I use Ford Pass to "remote start" my EcoBoost Maverick when leaving a restaurant, it runs only for 1 minute? Are we maybe thinking of "remote start" differently?
The Real Maverick
Jack
When you remote start a hybrid it runs "as needed". There is a maximum time limit, but no minimum time limit. And by run I mean runs the gasoline engine for no set number of minutes.
*You can remote start a hybrid (for cooling) and the gas engine may never start.
RR - All the way
GA
My next worry would be spontaneous combustion in my garage....:crying: Is it an attached garage??? I would park it outside until I knew what was going on. Of course, with Ford, that could take years.
Sykotyk
Ohio
As mentioned by another, the gas engine in a hybrid only runs when necessary. Even on 'remote start'. If you press it in the FordPass app, the car will turn on. But it doesn't start the engine. Once it goes through the boot-up and starts activating and checking all its sensors if it needs to, it will fire up the gas engine. If the battery is too low, the engine starts. if the battery is too cold or hot, the engine starts. If the climate control is turned to 'heat' and the engine is cold, the engine will start. If the climate control is turned off, and there's nothing else affecting normal operation, the maverick will literally just sit in 'standby' waiting for either you to enter the vehicle or the battery to draw down enough to need it to start.
Even then, just like with the Ecoboost, if the vehicle is only for a set amount of time with no 'ignition' by the driver to actually drive the vehicle, then computer will shut the vehicle down. I believe it's after 15 minutes.
I know when the vehicle HAS BEEN running, if you're parked for about 15 minutes or so (whether the engine has run or not) the display will ask you if you want to keep the vehicle on, or else it gives a countdown for it to shutoff. But that's with the key inside the vehicle (Lariat) or engine (XL/XLT) after already running/driving/key-start or button pressed.
As others have said, with this being used, it sounds like the FordPass is still on another person's account and they started it, OR there's a scheduled start that was still attached to the vehicle. Either the other user or he set one up by accident or maybe the dealer showed him how to do it, who knows.
But it is not in itself proof of some ghost in the machine doing it all on its own.
In Hybrid If you have cabin temp set to max cool or max heat the ice does not turn off. When hybrid starts whether attended or remotely the AC is turned on in the same setting as when it was turned off. In the past I have key readied my hybrid to charge the 12 volt and it stays in ready mode and cycles ice to add the 10% to the HVB as needed. Seldom if ever have I seen one ice cycle as short as one minute. But maybe 10 in cold weather. With AC and all lights, radio etc off the ice comes on less frequently. The initial ice run time can vary and I have seen 8 minutes or more presumably to maintain temps of HVB, cats, etc.
Dudley
Doug
Indiana
2003 Grand Cherokee
Mr. Hybrid is very different than Mr. Eco! Thanks, everyone!
