2- Bicycle Bed Mount - Any Thoughts?
tstor1402
Don
2025 Maverick
Here is my partially completed mount for anchoring 2 Delta fork mounts. It will be clamped down with a single 3/8” bolt thru the board w/clamp under bed rail. It should allow me to carry my road bikes without leaving tailgate down. Just added completed pics and tailgate is up and still have 1 1/2” clearance. *added bonus. Found out I can drive into garage with bike still mounted in the bed😀
Ford Maverick 2- Bicycle Bed Mount - Any Thoughts? IMG_2447
Ford Maverick 2- Bicycle Bed Mount - Any Thoughts? IMG_2450
Ford Maverick 2- Bicycle Bed Mount - Any Thoughts? IMG_2452
Ford Maverick 2- Bicycle Bed Mount - Any Thoughts? IMG_2454
caa60126
Chuck
Front Range Colorado
2024 XLT X4 4K Mav
Looks good, is that synthetic decking, not that it matters that much. If it is, it may sag a bit in the hot sun; a leg in the middle on the underside might help. Good job! oh never mind, it is supported the full length by the ledge, my bad
tstor1402
Don
2025 Maverick
There is going to be a 3/8x 1” strip of weatherstripping across the top of the bed in the front. There is also full pieces of pad covering the bed rail caps to keep from marring them.
budpalumbo
ohio
many
I had that same setup on my dakota. In the mav I cut the board shorter and put it up against the front of the bed on the bottom. Put our bikes in at an angle and I can shut the tailgate. No straps or anchors needed.
Cancunbadlands
Cancun
Cancun
#DIY like a pro!
Cancunbadlands
Cancun
Cancun
I use a hitch bike rack
Ford Maverick 2- Bicycle Bed Mount - Any Thoughts? 20251122_131236~2
tstor1402
Don
2025 Maverick
tstor1402
Don
2025 Maverick
I have aero bars mounted on both bikes so couldn’t get the mount far enough forward if I put it at the bottom.
Surly Old Bill
bill
Richmond, CA
2024 Maverick XL
That's a slick solution!
Marshall
Marshall
Greensboro
2025 Maverick XL AWD
Very inventive! Could consider a vertical piece between the mount board and the glass. Might protect it in case of a slip attaching the bike.
tstor1402
Don
2025 Maverick
I’ve been thinking about that and am looking to find a piece of 3” aluminum angle to sandwich between the board and the bike mount so I can use the same holes.
CaliMav68
JL
Ohio
2022 Maverick Lariat AWD EB
I love DIY solutions as much as the next guy, but I'd buy a hitch rack. Keeps the bed open and you don't have to remove and install the wheels twice for each outing. I know racks are expensive, so a much cheaper solution is to get a tailgate pad to throw the bikes over. Since you're obviously handy, you could even make one yourself.
