Is it possible to have a bicycle (with front tire removed) fit in the bed with a Hard Roll Tonneau cover ? Thank You.
Thanks for the reply. Based on internet photos it may be a tight squeeze. I think I won't know until I try.I haven't seen anyone try that yet. But I suppose it'll depend somewhat on the frame and wheel size. The bed dimensions are readily available though, so maybe compare to your bike (with the front wheel removed).
Thank You - that is a good point. The 5/6 inches from the wood plank to the front of the bed may give the depth needed to fit the bicycle. I'm guessing the wheel won't fit under the rolled up hard cover.If you attached a couple sections of 2X4 to the front of the board so the skewers were attached on top of the attached sections all the way to the front of the bed, maybe. Notice in the pics above they are putting the front wheel in front of the board because the is 5 to six inches left in front of the board.
Exactly, and you want to the side of your bike so your locking cable secures it too.think it will fit just wont be able to put front tire up were the photos above show it going
