2.5L Factory Engine Cover Definitive Thread
2024ash
Adam
Iowa
2024 Cactus Grey Maverick Lariat Hybrid
For those who have questions and are considering an engine cover for their hybrid, I wanted to collect all the information in a single thread. This is my first contribution, hope it is helpful!
I was fortunate to find a used junkyard engine cover from a Ford Escape Hybrid for $50 plus shipping. At my request, the yard also pulled the mounting hardware which includes a ball post and a retention bolt/washer/nut.
Ford Maverick 2.5L Factory Engine Cover Definitive Thread 1000005866
Ford engine cover 6A949 part number
LX6Z6A949B
LX6E6A949AB
*Or* do an interchange salvage yard search for 2020-2022? Escape Hybrid engine cover
Ball Post part number
6N958 stud is AA5Z6N958A
Ford Maverick 2.5L Factory Engine Cover Definitive Thread 1000005864
Retention screw part number (Just need one!):
HT1 stud is W714647S450B (also need H1N nut unsure if included)
Ford Maverick 2.5L Factory Engine Cover Definitive Thread 1000005865
My first impression is the engine cover definitively reduces engine noise. The transition to engine power is almost imperceptible and the sound level is noticeably reduced across the rev range. The distinct growl of the Atkinson Cycle, especially in the 20-30% power range, is attenuated but not muted.
Ford Maverick 2.5L Factory Engine Cover Definitive Thread 1000005860
The cover is made of urethane or rubber foam and varying thicknesses between 1/2" and 1" . There are four plastic pieces molded in for the mounting points for the posts and the retention screw.
Make sure you firmly tighten the bolt post or when you loosen the nut the post will walk out tear the cover (as you can see below).
Ford Maverick 2.5L Factory Engine Cover Definitive Thread 1000005859
Ford Maverick 2.5L Factory Engine Cover Definitive Thread 1000005858
There are four mounting points.
Ford Maverick 2.5L Factory Engine Cover Definitive Thread 20260423_142714
The front mounting posts are molded into the intake runners.
Ford Maverick 2.5L Factory Engine Cover Definitive Thread 20260423_142722
You will need the hardware for the rear ball post mount and the rear retaining bolt. Sorry, I didn't grab pics of these installed. They mount here:
Ford Maverick 2.5L Factory Engine Cover Definitive Thread 1000005857
And here:
Ford Maverick 2.5L Factory Engine Cover Definitive Thread 1000005856
And a video of the engine sound comparison with and without the cover.
Cheers!
Ford Maverick 2.5L Factory Engine Cover Definitive Thread 1000005853
SafetyGuy
Andy
Manitoba
Good job with the thread, showing what is all needed.
Your video really does clearly show the difference the engine cover makes!
Cheers,
Andy
hibred
tom
n.e. wisconsin
subaru outback hybred mav
I am working on a cover of my own design it will be 1/8 thick alum. with slots for air and it will have stand-of brackets that use the 2 threaded holes in back with the 2 ball mount studs in front . It will be a lot like the other brand that is made but for the hybrid. Will take pictures when i get a prototype done
2024ash
2024ash
Adam
Iowa
Looks like a great protected area for rodents to nest under.
That, along with every other nook and cranny in the engine bay, anywhere under or behind the dash, the HVAC filter housing, any cavity with insulation, and the entire interior including where the critical wires run under the rear seat. Rodents love cars.
I hope your post was intended to be constructive but the absence of context is not helpful.
MXGOLF
Oregon
2026 Maverick Lariat / 2020 Ranger SCAB / 2007 Yamaha FZ6
Thanks for doing that Adam. My Ranger had one the factory made and of course it was not on there stock. I did get that one and was wondering about the Maverick as there are the bolt holes on the back of the top of the motor I noticed. Cheap FORD.
2024ash
2024ash
Adam
Iowa
My pleasure. It's an easy five minute install, the challenge is finding the cover itself
Edit: forgot to add I agree this was a cheap cost savings move (just like excluding a hoodliner).
DGMavLove
NY state
2012 Escape, 2026 Maverick ordered
LX6Z6A949B
Lincoln engine cover part number
Make sure you firmly tighten the bolt post or when you loosen the nut the post will actually tear the cover (as you can see below).
And here:
Cheers!
Thank you. Your photos and description are very instructional and helpful. (I wish everyone would include photos.)
It's a discontinued part. They don't exist for the Maverick hybrid.
There are hopes that one of the Chinese companies makes a foam one similar to the one that was on the Ford Escape hybrid.
