2.5 liter for the Maverick only?
RustyF150
Rusty
Mansfield Twp., NJ
'08 Grand Marquis, '69 Chevelle SS L-78 Conv.
Is the Atkinson 2.5 liter engine used exclusively in the Maverick Hybrid or is it also used in other Ford vehicles? I know the 2.0 Ecoboost engine cover from other Fords can be transplanted to the Maverick 2.0 but I don't know about the 2.5.
JASmith
Jessica
Dodge Ram 1500
Its been around for a while, used in various Ford products such as the hybrid versions of the Fusion, Lincoln MKZ, and Escape.
Redneck Garage
Franklin TN
www.theredneckgarage.com
lanslide
Kevin Levesque
klphotos.zenfolio.com
2022 Lariat, Scrambler 1200XC
I owned a 2009 Ford Escape Hybrid and it had the Atkinson 2,5 liter. I can't tell young it has been updated or not but it worked great for me. It still used in the current Escape with even better mileage that the 2009 Escape.
Maverstang
Miata; Maverick Lariat Hybrid
The same Atkinson 2.5 engine is currently shipping in the Escape hybrid and PHEV models.
There are also strong suggestions it will become available in the 2023 or 2024 Bronco Sport, and the upcoming North American Transit Connect replacement (all are C2 platform vehicles).
RustyF150
RustyF150
Rusty
Mansfield Twp., NJ
RustyF150
RustyF150
Rusty
Mansfield Twp., NJ
Many thanks..
Scupking
CT
2022 Ford Maverick Hybrid
Isn’t the engine based off the Mazda L5 engine. Thought I read that somewhere.
RustyF150
RustyF150
Rusty
Mansfield Twp., NJ
I have since learned it's also in the Mazda Tribute so yes, you are correct. Thanks
BlueSnake77
Rochester NY
So the 2.5L in the Maverick hybrid is the same one I have my Escape? Geez it's been around awhile (since 2008 I think) and yeah it's a Mazda design. Some people have gotten 300k miles out of them. Supossed to be one of Fords most reliable engines. I change my oil every 5k miles.
Redneck Garage
Franklin TN
They are supposed to be very reliable indeed. 200,000 miles is common, over 300,000 is not that surprising if you do regular maintenance. Hopefully as good as my 2001 Ranger with a 3.0 V6 that was at 398,000 when an idiot employee fell asleep driving ( middle of the day) and hit a horse trailer and Suburban. Sure wanted to see how many miles I could get out of that great Ford truck :)
jsus
2022 Ford Escape Hybrid AWD 😉
No, your 2018 Escape has a different non-hybrid 2.5L engine.
RustyF150
RustyF150
Rusty
Mansfield Twp., NJ
Thanks a bunch.
bombast
Pennsyltucky
2022 Ford Maverick XL, Hybrid
As others said, the Atkinson engine in the Maverick is pretty old, and has been marketed alternatively as a Duratec or Mazda L in the past. I'm not sure why they just call it 'Atkinson' in Maverick documentation. Presumably its to make it sound newer than it is? Seems to only cause confusion, as most people seem to think its an untested accident waiting to happen rather than a tested platform.
Because it's an Atkinson Cycle engine (as opposed to a standard Otto Cycle) which describes an engine in which the compression ratio is different from the expansion ratio to extract more combustion energy. On modern engines that's typically achieved by using variable valve timing to increase intake valve opening time into the compression stroke so less volume is actually compressed.
