13 inch Center Display is not turning on
Kpankow
Kirt
Vail, AZ 85641, USA
2025 Maverick Tremor
So you pressed the >> button and the power button in the middle of the volume knob and this did not work?
The lower right button is the hang up the phone button but also has an > on it, and doubles as the forward audio button, this may be what they are referring to. I doubt it will help at this point though.
Yes, I tried that also. No go.
The whole truck is a bunch of computers basically.
Which in this case - means disconnect the negative battery cable for a couple minutes, before connecting again.
Or - if you already have Forscan Lite - there is a Service process for rebooting most the modules - APIM included.
Kpankow
Kirt
Vail, AZ 85641, USA
Will Forscan work with an ELMscan327? I do have a wireless OBDII dongle. It might be worth a try.
uga
SE USA
2026 Ford Maverick XLT
Disconnect the battery as mentioned above for 15 minutes and see if that works.
I should have added - check your manual for more steps for when you are connecting the battery back.
For instance this should be noted before disconnect.
Remove and Reinstall the Battery
Install a battery approved for use by our specifications. See Capacities and Specifications.
To disconnect or remove the battery, do the following:
  1. Apply the parking brake and switch the ignition off.
  2. Switch all electrical equipment off, for example lights and radio.
  3. Wait a minimum of two minutes before disconnecting the battery.
Note: The engine management system has a power hold function and remains powered for a period of time after you switch the ignition off. This is to allow the system to store diagnostic and adaptive tables. Disconnecting the battery without waiting can cause damage not covered by the vehicle warranty.
  1. Disconnect the negative battery cable terminal.
Kpankow
Kirt
Vail, AZ 85641, USA
Thanks for your advice. I'll give it a try.
I did connect with Forscan. No current DTCs, but i do see there were some past DCTs. Below is the section where these were listed. Ethernet failures in APIM are a concern I believe. I'll do the battery disconnect in the morning.
===GWM DTC U2401:00-49===
Code: U2401 - Ethernet Failure With Accessory Protocol Interface Module (APIM)
Status (-49):
- DTC Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
- Test not complete
Module: Gateway Module A
===END GWM DTC U2401:00-49===
===IPMA DTC U0253:00-2F===
Code: U0253 - Lost Communication With Accessory Protocol Interface Module
Status (-2F):
Module: Image Processing Module A
===END IPMA DTC U0253:00-2F===
===IPMA DTC B1578:89-28===
Code: B1578 - Digital Park Assist Camera Vision System
Additional Fault Symptom :)89):
- Data Transfer Failure
Status (-28):
- Previously Set DTC - Not Present at Time of Request
Kpankow
Kirt
Vail, AZ 85641, USA
Status (-49):
- Test not complete
Status (-2F):
Status (-28):
As wierd as it stopped working days ago, All is working fine after connecting with Forscan. I didn't run any Service Module Resets and there were no DCTs. All I know is I started it up after disconnecting from the OBDII so I could run it for a while and make sure the battery was up and damn the display is magically working again.
notfast
Los Angeles CA
I had almost exactly the same thing happen with my Ford Edge (which I think had Sync 2). The center screen and the right instrument cluster screen just froze one day while cruising down the freeway. HVAC still worked since there were capacitive touch buttons. Did the whole song and dance to try a reset and disconnected the negative terminal on the battery to no avail.
Plugged in a Snap On tablet to check all available modules. Found nothing except some occasional U0100, which in and of itself isn't really alarming cuz they can be triggered for any number of reasons.
Figured it'd have to go back to the dealership. Started it up to move it out of the way and...the screens booted up and resumed like nothing was ever wrong. I racked on like 150,000 more miles on that car and it never did it again.
Kpankow
Kirt
Vail, AZ 85641, USA
My 2025 Maverick Tremor Center Display just stopped working. It's just a black screen. 1,700 miles on the odometer. Fuses checkout ok. Of course the local Dealership can't look at it for week. Anyone else experience this?
The display is back to normal operation. Thanks to everyone who responded to this post with your recommendations and ideas on how to solve the issue. I tried everything, Nothing worked. Scroll down to my last post to see how the display magically started working again. Weird, just weird!
Kpankow
Kirt
Vail, AZ 85641, USA
Well that was quick. It lasted one day. I turned on the truck yesterday and once again, no 13" display operation. Glad I didn't cancel the dealership appointment.
Kpankow
Kirt
Vail, AZ 85641, USA
Did you get it in for service? Curious what they found.
It's been at the dealership for 6 days so far. They said the problem is in the display itself. We are waiting for the replacement part. No ETA. At least they provided a 2025 F150 XLT loaner for free. The Maverick being my first ever truck, I'm sure I'll never get a full size truck. The F150 drives great, but parking lots, garages, etc are just a pain for me.
After I had my backup camera recall done. I had some popup screens one was no camera found. The backup camera was working so maybe it was for the front camera. Who knows. The remote tech had left an said that he was booked up, couldn't turn and come back until 2nd day. Said if I wanted I could try disconnecting new battery cable for 10 minutes and if that did not work try 30 minutes. Neither worked. Went out about 4 hours later and it worked fine. Tech came by on his scheduled time and reset all codes including history. Have not had problem for six weeks now. Do not know but half of time I will double lock my truck to shut down the delay off circuits early and maybe I did that before I left truck for the four hour rest. Maybe that shutdown turned something off and helped. No idea.
Kpankow
Kirt
Vail, AZ 85641, USA
Thanks to all for the response I received in trying to fix this issue on my own.
It took two weeks for the dealership to receive a new display unit. They installed the new one and all is fine now. On a side note, the Maverick Tremor is my 1st ever truck. After driving the loaner F150 XLT Crew Cab for two weeks, I reaffirmed that I will never own a full size pickup and my choice on a Maverick was the correct one.
