12V flex bed no power
Kizyle
Kyle
Ford Maverick XLT
After installing a 12v power panel in the back, I now have no power to the 12v pigtail on either side. Pretty sure I touched the wires together on install and popped a fuse. I found #83 appeared to be blown which was a 20amp but in the manual it says it is a 40amp? #84 was good, which I thought would be the problem. I have literally pulled every fuse from the engine compartment and just about every fuse from passenger side with nothing popped. Reconnected the bottom part of the other pigtail under the truck. I’m so lost and have no clue. It’s a 24 hybrid.
TheWizziard
Texas-RGV
2023 Maverick XLT Oxford White
Fuse #84 is a 20 amp fuse for the "Pick-up box power point"
The closest 40 amp fuse is #83
Kizyle
Kizyle
Kyle
Ford Maverick XLT
Ya I just have no idea why I don’t have power in the back
BlueSpec1
Gene
Still no bed power after replacing the blown 20A MCASE+ fuse?
The owner's manual seems to have the fuse # for 82, 83, 84 different vs. the service manual.
FSM:
Ford Maverick 12V flex bed no power BJB Fuse #82 [F102. 40A]. #83. [F34, 20A], #84, [F36, 60A]
Ford Maverick 12V flex bed no power BJB - F34 20A - Bed Point Point LH, RH
Ford Maverick 12V flex bed no power BJB Fuse Position# & Fuse F#
Kizyle
Kizyle
Kyle
Ford Maverick XLT
I checked every fuse in the engine compartment, I checked just about every fuse under the glove box. I unplugged the pigtail harness underneath the car. I don’t know what else beside disconnecting the battery and hoping for the best. I don’t know what a tech at the dealership will find. Don’t know if hooking up a computer will find something I can’t see.
Grand Nat.
NYC/ L.I
Schwinn Stingray
Does your USB charge point work?
Kizyle
Kizyle
Kyle
Ford Maverick XLT
Is that that the charger In the front dash or the one in the center console in the back for rear passengers?
Grand Nat.
NYC/ L.I
Schwinn Stingray
I think it's the rear one but check both of them. I assuming that you're starting the engine and then checking the PowerPoints.
Grand Nat.
NYC/ L.I
Schwinn Stingray
Using the Ford wire adapter check the current from there. don't ground to the vehicle.
BlueSpec1
Gene
I was checking my RH side before I use the pigtail, no 12V there till turn to accessory mode or run. So I didn't think I'd blow a fuse while wiring in unless I miswired it.
Ford Maverick 12V flex bed no power RR Molex MX150 4 Pin Female to MX150 2 Pin Female - OEM at 12V Blanking Plate - IMG_4572
Kizyle
Kizyle
Kyle
Ford Maverick XLT
I got power to both of the cigarette outlets. Are you talking about checking the pigtail (12v accessory wire) voltage?
Kizyle
Kizyle
Kyle
Ford Maverick XLT
RR Molex MX150 4 Pin Female to MX150 2 Pin Female - OEM at 12V Blanking Plate - IMG_4572.webp
No voltage to either side in the flex bed
Grand Nat.
NYC/ L.I
Schwinn Stingray
RR Molex MX150 4 Pin Female to MX150 2 Pin Female - OEM at 12V Blanking Plate - IMG_4572.JPG
Do you mean there is no voltage until you turn on the ignition? Then you get voltage?
The 12v on either side of the bed are on the same 20 amp fuse and when you turn off key they remain hot for the time delay period.
