Red454
Indianapolis
2011 Fusion, 1972 Impala, 2005 Mustang
I wanted to add one of those little charging blocks that have the 12 V cigarette lighter plug as well as a couple of USB charging ports. I didn’t want to cut up the factory panel so I used a piece of material that is used for machine guarding. It is thin aluminum on two sides with a plastic core sandwich in between. Very easy to machine.
Ford Maverick 12v Charger Panel Mod for Bed Cubby IMG_6758
Ford Maverick 12v Charger Panel Mod for Bed Cubby IMG_6759
Ford Maverick 12v Charger Panel Mod for Bed Cubby IMG_6761
Ford Maverick 12v Charger Panel Mod for Bed Cubby IMG_6760
Darklyter
FL
XL, like me lol
Noice!! Would you mind sharing the part / item/mfginfo for the aluminum sheeting material?
Phimosis
Larry
Santa Clarita, CA
Personally, I would have went with solid 3/8” plate to handle the full 60 lb/ft of torque that your 1/2” bolts are rated for.
Valar M
Rax
Los Angeles
SUVs
I like that material for creating these mods. Do you have any better identifying info for getting some of that?
Blinky
Alberta, Canada
It's called Dibond but like most industrial products there are probably other names it goes by.
It can usually be had from better stocked art and picture framing stores, and I've gotten it from sign shops, they almost always seem to have small off-cuts for projects like this.
Valar M
Rax
Los Angeles
SUVs
Th
thank you
Valar M
Rax
Los Angeles
SUVs
Just a quick shout out to the OP.
Coming here to see other’s projects is always made better when details are shared, like the material used on a fabrication like this one. The OP shared it, I’ve ordered it, and now I’m that much closer to a cool project finish.
thank you
Red454
Red454
Indianapolis
thank you
Post some pics when you are done!
