12v and USB installed in bed
Clarkdonbran
I really want to do that! I would electrocute myself or destroy my Mav though.
Decayed
yes
a car
You would be surprised at how simple it really is. All you really need is a spade bit that's the right size and a couple of wire nuts.
Clarkdonbran
I don’t know. Electrical stuff scares me. I’d probably just pay someone. Does that run from the DIY electrical in the bed? I wonder if I could put a 12 volt right where that is.
Decayed
yes
a car
Not sure how he wired it but very likely all he did was attach the pigtail and connect the wires. The 12v accessory cover looks a bit too small for even one socket. But if you remove the panel where he mounted it, it's all open behind there, so connecting the wires should be a snap. The hard part is drilling the holes in the right place but the worst you could do is bork the panel and have to order a new one.
FWIW I am planning on doing pretty much exactly the same mod if I ever get my truck.
Hizzy8122
Hizzy8122
2020 Ford Maverick
Nah. Its only 2 wires. Red and black. Super simple. You don't even need to disconnect the battery.
Hizzy8122
Hizzy8122
2020 Ford Maverick
Yes it does. 2 wires. You can't mess it up
Dimes
Oklahoma
Escape
There are other drill bits that are easier to use for those less experienced in such things.
Pappy
Worthington Ohio
2022 Maverick XL Hybrid
The two touch-control LED bed lights were a dealer installed option that just came in today; they came in handy late this afternoon as I finished installing a marine grade 12v power outlet in the bed cubby to run a 15amp Pittsburgh Tools air inflator.
Ford Maverick 12v and USB installed in bed IMG_1163
Ford Maverick 12v and USB installed in bed IMG_1164
Ford Maverick 12v and USB installed in bed IMG_1165
