12 Volt bed outlet - what can it safely power?
Yellowjacket
2025 Maverick, 2015 Transit,
Can anyone tell me what can safely be operated on the 12 V bed outlet. Im thinking about getting rv cooler fridge.
El Kabong
Carnation, WA
Do you mean the 12v power that you can add your own connections to?
It's in the owners manual... 180 watts (15 amps) **edit: COMBINED TOTAL for BOTH**. Likewise is the 120v power outlet (if equipped) which is limited to 400 watts (3.3 amps) **edit: COMBINED TOTAL for BOTH inside and bed location**.
Ford Maverick 12 Volt bed outlet - what can it safely power? 12v bed power
Tbone289
You'll have no problems running a compressor style cooler from the bed supply. I do it all the time time. Most won't pull more than 5A of current.
SafetyGuy
Andy
Manitoba
Good day @Yellowjacket
Here are a couple examples of what we use...in our Maverick it is a DC cooler, requirements in photo, and our RV Fridge/Freezer, 3.2 cubic feet I believe and pick your power source.
Both would work amperage-wise, keep in mind motors take up to 2 or 3 times momentary voltage when starting so must allow for that when sizing your device.
I ordered my rear 12 volt plugs through @Maverick_Innovation_Designs (through Etsy) and highly recommend his products.
12 volt Igloo cooler
Ford Maverick 12 Volt bed outlet - what can it safely power? 20260621_123055
Ford Maverick 12 Volt bed outlet - what can it safely power? 20260628_145404
This is the rv fridge info.
Ford Maverick 12 Volt bed outlet - what can it safely power? 20260628_152854
Ford Maverick 12 Volt bed outlet - what can it safely power? 20260628_152523
Ford Maverick 12 Volt bed outlet - what can it safely power? 20260628_152518
Have a great day, and I hope this helps you in your search.
Andy
MaverickDragon
Grand Canyon, AZ
I believe the vehicle needs to be running to supply the 12V to that bed outlet.
I believe you are right, or at least the ignition needs to be on to get power to the bed plugs in my 25 XL - No ignition on = no power to the rear bed plugs - I just tested that hypothesis.
Power is already off by the time I exit the vehicle to check the voltmeter.
It does make me wonder why the manual would state to not drain the battery by leaving devices plugged in overnight or when parked when there is no power to the plugs unless there are model trim/year differences...
I have the 25 XL and @El Kabong has a 26 Lariat...
EDIT: I found that if any power is being used by the rear bed power points at the time of vehicle shutdown, the power remains active, provided battery SOC is adequate and the built in timer has not expired.
Tbone289
No, it follows the timer that controls all accessory ports. Mine runs for 90 minutes after the ignition has been shut off, which is plenty of time to eat a meal.
At least thats how 2022-2024 works.
El Kabong
Carnation, WA
I have not tested but assume the Lariat will also shut off power to the 12v lines after the timeout period. The Lariat is just a trim level that adds features. All the stuff on an XL that is on a Lariat will work the same (and, with time and money, you can fit many XLT or Lariat features to your XL).
I've seen multiple threads where folks who camp/overland have fitted auxiliary power solutions like power banks in the cabin or under the rear seat for long-runtime power to stuff like coolers, no reason the same idea can't be fitted into the bed area.
Tbone289
Tbone289
I should add that running a 12v accessory from the AC outlet is very inefficient, as it will be going through DC-AC-DC conversion.
El Kabong
Carnation, WA
Thank you,. I meant to say 120 outlet
The 120v outlet also switches off. So if you need the AC powered cooler to be on for extended periods the fitment of an offline aux power thing is the way to go.
SafetyGuy
Andy
Manitoba
Good day
For clarification on our Lariat hybrid (with a fully and properly charged 12 volt battery...turn your lights on all the time) I know our rear 12 volt power ports remain powered till the truck shuts everything down, at about 70 minutes-ish after truck shut down). ...Barring 12 volt battery issues, which would shut the ports down as soon as immediately, to save the 12 volt battery for its next start.
I am wondering what is going on with your truck @MaverickDragon that your hybrid shut down its 12 volt power immediately...our 2025 Hybrid stays on as I just tested all situations as well.
For our hybrid, 120 volt shuts down immediately when engine is turned off, but 120 volt will stay on as long as the truck is on and engine can cycle on and off as it decides when to do it.
We were out fishing on sunday, and with truck power completely off, 12 volt powered rear port power stayed on and the cooler kept running, keeping our food and beverages nice and chilled...the way I like it.
With different trucks with different 12 volt battery charge conditions, experiences will vary greatly, I am thinking.
Andy
