You can Flip the USB ports
mapnerd
2024 Maverick Lariat Tremor
2024 Maverick Tremor. Since it has Sync3, I don’t have wireless CarPlay so I bought a wireless CarPlay dongle. The dongle is USB-A but comes with a USB-A to USB-C adapter. Since all of my devices and charging cables are USB-C I decided to use the USV-A port for the dongle so that I could keep the USB-C port free in case I need to charge a second device or a passenger wants to charge.
My OCD hates that the USB-C port was on the top so I popped it off and filliped it upside down . No mods needed. Just a small flathead screwdriver or pry tool.
Now the CarPlay dongle is up out of the way and the USB-C port is easier to access as it’s not right beneath that ledge. Not sure if this bothers anyone else but my fantastical brain is happier with that small tweak.
Ford Maverick You can Flip the USB ports IMG_5428
Ford Maverick You can Flip the USB ports IMG_5429
Tbone289
Your brain is more fantastical than mine. :wink:
I'll agree, that's some OCD. Awesome that simple solution made you happy. One question though, did your screwdriver gouge the plastic in the process that much around the usb ports??
REDRUM
Central Jersey
2025 Maverick XLT
It would bother me.
My usb has a little light on when being used.
My OCD has to see that light so upside-down won't work.
What is that to the left of your usb ports?
Is that an ashtray?
Did you spring for the smokers package?
My 2025 doesn't have that.
mapnerd
Yeah it did. I should have used a towel or a proper pry tool. I didn’t expect the plastic to be quite that soft.
nothing stays perfect forever and I sure didn’t buy it to admire it.
mapnerd
It would bother me.
Is that an ashtray?
To each their own.
it’s just a 12v socket. I don’t smoke and even if I did, are smoker packages still a thing?
Ford Maverick You can Flip the USB ports IMG_5430
gjallen3
Jerry
Arizona
2024 Maverick XLT
I too was thinking about doing this. I've tried three different dongles each with their own limitations. The one you installed is pretty small. I like that. Are you happy with it's performance? If so, where did you get it?
Mark’s Mav
Tennessee
2025 Hybrid Lariat AWD
It would bother me.
Is that an ashtray?
That’s the switch for the rear glass window on a Lariat.
ScottyC
Central NY
2025 Ford Maverick AWD hybrid
But, now the USB image points in the wrong direction and everything plugged into the USB-A port would be upside down....would that also not trigger an OCD alert? :wink:
On the plus side, the USB image now looks like a depiction of the new Ford assembly line going in at Louisville....so, you should be ok....
mapnerd
I’m only a few days into it but so far it seems to work just fine. I jump in the car and drop my phone on the charging pad. I have an automation configured to automatically turn on Bluetooth when my phone is charging and it turn it off when my phone stops charging. By the time I have my seatbelt on and I’m ready to put it in gear, CarPlay is connected and displaying on the screen.
I wanted one as small as I could find and I haven’t seen one smaller. I’m using this one: https://carlinkitcarplay.com/products/carlinkit-mini-ultra-wireless-carplay-android-auto-adapter
Kate
Albuquerque, NM
2024 FORD Maverick
Does this work with Samsung ultra s25? My current wireless plug in worked flawlessly for s22 but continually skips on all audio on the upgraded phone.
SP1966
Vegas
2024 Maverick XL Hybrid
It's going to drive you nuts once your roll the truck onto it's roof!
mapnerd
Samsung phones would use Android Auto but yes, it supports both CarPlay and Android Auto. As to whether or not it specifically would support the S22, I can’t say definitively because I don’t have that phone to test with, but it should.
it’s not very expensive. Give it a go and if you don’t like it, return it.
