Adding USB ports under the rear seat in the storage bin?
BirdDog
Has anyone seen a way of putting USB charging ports under the rear seat in the storage bin?
SLJ
Elbridge New York
All you need is to find or run 12 volts. There's a lot of marine "PD" type USB ports in any combination, switched, USB C, etc. you could mount in there that run off 12 volts. https://amzn.to/3S1GumW
Luthinator
24' Mav. Lariat Hybrid & 23' Ford Explorer XLT+
USB output is 5 volts. Wiring a USB cable directly to 12v will damage devices connected to it.
I would either use an adaptor like this
https://a.co/d/1xX7ZFM
OR just plan to use usb C @ 12v for the plugs. if you need 5v, I would use the above adaptor for the install or use an inverter.
Luthinator
looking at this product, it appears to take 12V and converts down to 5V.
SLJ
Elbridge New York
These convert and drop down 12 volts to 5V USB ports. Widely used on boats and campers for adding USB ports. I've installed a lot of them in different combinations.
lewiskauffman
Lewis
Chambersburg PA
2022 Ford Maverick XL
All true. My words of caution were aimed at the first part of the post- ' All you need is to find or run 12 volts. '
When choosing your device to connect to the "12 volt line" be sure to get one that will accept up to 15.6 volt input. If you get one with a lower over voltage protection you will loose the USB 5 volt current when the mavericks current exceeds the devices max voltage limit
