XLT sun visors won't turn on
MaveRican
Luis
Riverview FL
www.instagram.com
White XLT
My 22" XLT don't have lights on the sun visors. I just purchased and installed sun visors with integrated lights from a another maveric but it won't turn on? Does anyone knows why?
KsuMax
St Petersburg
2024 XLT Tremor
That was going to be my question, what did you use to power the lights?
MaveRican
MaveRican
Luis
Riverview FL
www.instagram.com
White XLT
There's one oem in place already, i was thinking and hoping it would be a straight swap. I guess ford had different plans!
Bwicka
Lakeside,ca.
Probably needs an enable turned on on the bcm using forscan .i would reach out to the forscan experts/ forum.
KsuMax
St Petersburg
2024 XLT Tremor
Dang, I would think it would have been powered right away. I’d also like to swap out mine for one with lights.
There shouldn't be any BCM specific control for just the visors. They're wired on the same power circuit as the general power for the front and rear dome lights.
89-2 are the visors. They just have a switch that should close to ground when opened.
Ford Maverick XLT sun visors won't turn on 1733236913419-ji
MaveRican
MaveRican
Luis
Riverview FL
www.instagram.com
White XLT
Hahaha. That's what I tough, just a open or close state. Some on FB said it need it a specific wiring harness. I gonna check if they shipped them without bulbs! 😳
Somebody already done them. Have you searched??????
Toddman45
St. Louis, MO
I noticed the XLT at least on my 24 already has the wiring harness going to the non bulb sun visors. I have no interest in lights for the visors but I'm sure there's those that will. I noticed the existing wiring harness when I took the visors out and removed the heat pressed stickers.
mepot101
Orlando, Fl
2024 Ford Maverick
Check the wiring with a test light. Then run wires straight from a battery to the visors to see if they work at all. Maybe the bulbs are shot?:sadface:
Mr Pibb
Vegas
2024 Lariat
What method did you go with to remove the stickers?
