Windshield Wiper Question
rclee
Rob
Dayton Ohio
Hi all, I just bought a new set of wiper blades for my 22 XLT. According to the Rain X catalog the driver side is 22 inch and the passenger is 21 inch. I pulled the driver side and compared it to the Rain X blade I purchased, there was a one inch difference. The original blade is 23 inches but the catalog spec's it as 22 inch.
Do I really have a UNICORN when it comes to wiper blades? Could someone check their drivers side and tell me the length of the blade from end to end?
BTW the passenger is 21 inch like the catalog says (and that is the noisy one when using the delay setting)
Thanks Rob
Tailender
Will
Poconos
I don't have the original blades but as long as the longer one doesn't hit anything, it shouldn't be a problem. You are correct that the drivers side is supposed to be 22 inches.
Ranch
Sacramento CA
2023 Marverick FX4 4K
I just measured my OE LH wiper blade and it's 22 3/4".
Tim d
Alpena
Ram
Thanks Rob
Curious if the blades were defective from the factory? I typically replace every 6-8 years.
MaverickEVwouldBeNice
Earth - Northern Hemisphere - North America - USA
2023 Mav Hyb/lux
Where do you live? Does it only rain twice a year?
I've not had blades last longer than two years, and I don't buy the cheapest I can find.
Tim d
Alpena
Ram
Upper Michigan. I clean them with comet and water every fall then dress with armor all. My ram is 14 years old and I've only replaced the blades once so far
GPSMan
Many
The "rubber" blades are good for 2 years. 3 tops.
You probably replaced them and forgot. Or got "curtesy" replacements done during an oil change here or there.
They won't necessarily fall off in 6-8 years but won't work well either. 🤷🏻‍♂️
I'll walk that back a little bit.
My last TWO vehicles I had on 3 year leases I never changed them. Seemed just fine at the 3 year return.
So 4 years seems totally possible.
icegradner
British Columbia, Canada
2022 XLT Maverick Hybrid
UV from sunlight, or running them when the window is dry, does far more damage to the blades than using them for rain or snow. I live in a coastal rain forest, don't change my blades very often either. Maybe every 4-5 years. I've always used OEM blades. 🤷‍♂️ This is my first Ford/American OEM vehicle though.
2023 Mav Hyb/lux
That would explain some of my blades. I lived in central TX for 8 years, don't tell my insurance company, but my vehicles weren't as regularly garaged as they may have thought.
Now I live in eastern WA, our summers are near as hot (and drier) as they were in TX, just slightly shorter.
My wiper blades last through a couple of winters, max, but I do admit that I am not as good about cleaning them as @Tim d
rclee
rclee
Rob
Dayton Ohio
Mine are almost 20 months old and are starting to chatter across the windshield. On my Honda Element, I would get about 2 years on the factory replacement wiper refills.
BTW has anyone measured their drivers side other than @Ranch ?
Samus
MD
'23 Tesla Model 3 Base
Just did. 23" The squeegee part itself was less.
Montana
Drivers side: WW2054
Passenger side: WW2249
For the price, they are great blades. I've even disassembled mine and flipped the rubber once so far. I bought a second set just to have as extra, but I plan on flipping the blade until I no longer can. A little effort compared to some blades to flip, but I'm not paying $30+ for the same quality of wiper blades from another brand. The rubber is no different.
Also:
Chatter fix
My part list post
rclee
rclee
Rob
Dayton Ohio
rclee
rclee
Rob
Dayton Ohio
Also:
Chatter fix
My part list post
Thanks @Montana for the tips!
Optimus
MN
2023 XLT Hybrid
I usually ignore the OEM length and see if I can put on larger blades regardless. Most vehicles I can usually get an inch or two more out of it. The extra clearing is most helpful for snow/winter. I have not checked our Mav yet as it’s brand new, but I expect 1-2 years out of OEM blades. I applied a ceramic coating to the glass, which may alter my results. After these wear out, I will switch back to my usual PIAA Super Silicon blades. Going on 5 years on 2 different vehicles. They are amazing and last far longer than the common cheap blades.
