Will these wheels/tires fit or not?
EONR24
Swag
United States
2024 Ford Maverick XL
I am curious if the "NEW SETUP" picture below is going to be too close to the Maverick's Suspension Components! Someone out there let me know if this will be ok or not!
Ford Maverick Will these wheels/tires fit or not? Screenshot 2024-04-02 at 11.52.02 AM
EONR24
EONR24
Swag
United States
Bump will there be enough clearance with this set up? says wheel/tire will sit 30 mm closer to the suspension about 1.25 inches.
Mervin the Maverick
Ken
Sierra Vista, AZ
2019 Kia Niro, 2019 Hyunda1 Kona, 2002 Chevy S10
Did you try Tire Rack or Discount Tires Websites to see what they say?
EONR24
EONR24
Swag
United States
Yes. Because the wheels are not OEM Maverick wheels they are 18x8 instead 18x7 and have a different offset, those websites don't know. Thanks for the suggestion though!
Hot Runr Guy
West Chicago, IL
Do you have access to a short piece of 2x2 or 2x4, which is 1-1/2" thick? If so, you could see for yourself if you have that much room on the back-side of your existing tires/wheels, check with wheels straight and at both fully turned positions.
HRG
EONR24
EONR24
Swag
United States
HRG
Good idea. How would I test if say I hit a bump? would their be less clearance when the suspension is under load??
Hot Runr Guy
West Chicago, IL
Maybe use a floor jack to get some vertical travel? What is so special about that particular wheel that you have selected it? Do they not offer other widths/offsets?
HRG
EONR24
EONR24
Swag
United States
HRG
So I have an OEM FOCUS ST Wheel SET they are 18x8 55 offset instead of 18x7 38 offset of the factory maverick wheels.
AzureBlueBill
Torrington, Connecticut
They will most likely work O.K. But just to be sure, I'd try to find a +45mm offset wheel instead.
EONR24
EONR24
Swag
United States
