Will Escape wheels fit my Maverick?
john herring
jphn
hannibal mo
mavericxk larirt
i have found some rims i like question will rims off of a escape fit my maverick
paneubert
Seattle
Maverick specs
Size:
17x7" or 18x7"
Width: 7" width
Offset: +37.5 mm
Bolt Pattern: 5x108
Center Bore: 63.4
Thread Size: M14 x 1.5 lug nuts
If the rims you found match those where it matters (bolt pattern and center bore mostly), then sure. If the center bore is larger, you can add rings to compensate.
ShadowChas
Chuck
2022 Ford Maverick XLT FX4
yes escape is same (update /sorry yes the newer escape 5x108 at least 17” size or larger)
RedRider
Kitchener, Ontario, Canada
I think the bolt circle changed on the Escape and a lot of other Fords to 5x108 in 2017. So they will only fit if they are from a 2017-up escape and are not the 16-inch ones from the low-end model.
FischAutoTechGarten
Peter
Here's your escape Offset:
Ford Maverick Will Escape wheels fit my Maverick? 1702860824756
So, you're comparing a 37mm to 48 or 52mm offset.... So 11 to 15mm.... Let's just call it a 1/2" difference... That's the spacer you want if want identical offset... Otherwise, your rims/tires will sit more inboard...
tom_tucker
mid atlantic (VA)
2023 Maverick XLT (FWD)
Escape wheels, wow. Why stop there? Why not Fiesta wheels or Eco Sport wheels?
:ROFLMAO:
JP4AZ
Phoenix
On my cyber orange Maverick, I am running Mach-E wheels (offset 47.5) and I have no problems with fit. Tires are 236/60/18.
Ford Maverick Will Escape wheels fit my Maverick? 20230915_142342_resized
