Why is my Mav doing this?
Clarkdonbran
The ICE kicked on immediately because I didn’t drive all weekend and 20 seconds in it started to make that sound. It went away after shifting into reverse. What is going on?! Don’t mind the 6 year old in the background.
bombast
Pennsyltucky
2022 Ford Maverick XL, Hybrid
Can't say I've heard that particular noise before. I have heard my maverick sound like it's under load when starting but before driving - I thinks it's the engine trying to warm itself up as fast as it can.
I'd check with the more mechanically inclined, but it's my understanding other components can be forcefed heat as well, which may account for strange noises. The exhaust and transmission and connected to the heating system I believe.
Mavreezy
Peter
Long Beach, CA
My truck used to make that same exact sound in the cold mornings when the ICE kicked in. After a quick drive it quickly disappeared.
I brought it up to the dealership on my last oil change. They didn't tell me if they did anything, but I've noticed it hasn't returned.
Again, it only did it in the morning when it was cold and the ICE kicked in for the first time. It sounded like loose plastic shroud bouncing around and hitting up against something. Hopefully it doesn't return...
SLINGSHOT
Charles
NE Iowa
2017 RAV4
Mine makes more noise at 7 mph cold than it does at 70 mph on the hiway. In fact, on the hiway, you can only tell if the ICE is running by looking at the EV Coach screen. Really quiet on the road. I figure if the early racket is really a problem, it would magnify at road speeds.
Zardoz
Murray
New Jersey
Just a guess, but it sounds like heat risers rattling, but I thought they got rid of them years ago.
dhill59
2023 Maverick XLT
I believe another member had diagnosed this as “tractor mode”.
Mine does the same thing.
r100gs91
The center of the USA
Sounds like an exhaust leak.
Sort of, I seldom hear mine do it as I come out of a garage 95% of the time. Only once has the ICE started instantly. It sat in 17° F for about 7 hours. That puppy fired right up but didn't sound "course"
Clarkdonbran
Clarkdonbran
Fuuuuuuuuuck. I fear it’s going to be one of those dealer couldn’t replicate things and waste my time.
Ranch
Sacramento CA
2023 Marverick FX4 4K
If it's making the noise all of the time it should be easy to figure it out. If it's intermittent then good luck.
Mikknj
Mikk
New Jersey
Maverick XLT Luxury CO360
That's normal don't worry about it -Mine does that when it's cold. I think this may be related to the emissions engine retune - vehicle won't hold emissions when run at top speed.... Which in itself is a crazy recall. It seems to be an engine tuning thing... I would take it to the dealer and ask them for a fix. Others have and there is none per-se but I'm sure it will get sorted out at some point. After it warms up it will run normally.
Clarkdonbran
Clarkdonbran
Thanks! I just hate my neighbors with Tesla’s thinking I have a shitty car.
lajlmt
Lance
Rio Rancho
‘23 Maverick XLT LUX
Did it convert to diesel😳
