Wheel question.
ttownmaverick
Tulsa OK
2025 Maverick XLT Hybrid AWD
I have 25 Mav with Black 225/55/19 wheels and tires. I don't like the Black wheel and I'm thinking of changing wheels. I've never changed wheels before and it's hard to find much in 19" wheel, well a least that I like. I found one that doesn't look bad after much searching and it's got the right bolt pattern and 35mm offset which I think would be ok. The width is 8 1/2" instead of 7 1/2" as on the OEM wheels. The shop says the tires will fit on them fine. Will they, that is my question. I'm talking about putting the Goodyear wrangler HT 225/55/19 on the new wheels.
Mudduck
JD
Utah
24 Maverick FX4. '26 Toyota Sequoia TRD Pro. 72 VW Ghia
I have a set of the same 19s with the machined/silver face if you care to swap?
ttownmaverick
ttownmaverick
Tulsa OK
I would love to if you were closer.
Mudduck
JD
Utah
I am in Texas for a few days. Close to Dallas. I don't mind making the drive...
ttownmaverick
ttownmaverick
Tulsa OK
Can i see a photo of them. Here is mine.
Ford Maverick Wheel question. 20260529_151019
Mudduck
JD
Utah
Absolutely. You can keep your tires as well. I have a new set in storage. These have 4977 miles on them, good wear nothing uneven or cupped.
Ford Maverick Wheel question. IMG_3332
Ford Maverick Wheel question. IMG_3072
ttownmaverick
ttownmaverick
Tulsa OK
I want to put my tires on. What kind of tires do you have.
ttownmaverick
ttownmaverick
Tulsa OK
I sent you a direct message.
Tim d
Alpena
Ram
Apparently they will.i replaced the tires on my antique muscle car recently that had different size front and back wheels. The back wheels are one inch wider and all 4 tires are the same size. I did not know this could be done.
Bobby Chapman
Bobby
Orlando fla.
2023 maverick
I Got these from discount tire on my 23xl ,40mm offset. No problems. Discount can order any wheel you find
https://www.walmart.com/ip/Motiv-20...MIvbOY2oXigQMVTmhMCh1oyA5XEAQYByABEgKECfD_BwE
Ford Maverick Wheel question. 20250326_094923
Cancunbadlands
Cancun
Cancun
Wheels swapped
