Donaldw
Donald
Oakland, CA
Forester, insurance pmt. from stolen tacoma.
I think we have the McGard. Couple thoughts. I want them to be noticeable because I think it is a better deterrent. Also, yes, there are different sizes. One store sold me the wrong size. Went to a different store and got the correct size.
Blinky
Alberta, Canada
I'm cheap, these are fine. When they get to beat up I will buy another set I guess.
I had a set of those and the gorilla red equivalent. Just be aware that the plating will probably last a year, at best.
The White Knight are good lugs and in chrome or black they're fine (black have lasted 5 years now) but the color options are just transparent paint over chrome. The Gorilla are of course great quality other than the finish, but same problem, transparent paint over chrome.
RangerMaverickGuy
Ontario, Canada
2024 Maverick XL with 4K Tow Package
Yes, I got that too when I was looking with Amazon, but I knew that the 14mm x 1.5 was the criteria to go by.
As per my initial post, I had tried a different model of Gorilla locks that were 14mm x 1.5 that fit just fine, but didn't have the larger cone seat like the OEM lugs have. I believe that Gorilla by not listing by vehicle criteria and/or by not being up to date with their product info. may be why Amazon doesn't recognize this particular model as being suitable for the Maverick.
I bought the same Gorilla 96641DX from amazon and are happy with the look. Nothing is impossible to remove but may slow down the thieves and gives more time for them to get caught.
AzureBlueBill
Torrington, Connecticut
What do these locking lug nuts weigh compared to the stock lug nuts? If you run one locking lug nut with the stock lug nuts you may encounter a wheel balance issue if the different weight is too great. I have noticed this with light weight wheel/tire set ups.
The nuts are close enough to the center so as to not throw off the balance much. I personally have never had an issue with them. This goes back for about 45 years of using MGard type locks. (yeah , I'm old)
Limeymav
Aden
Titusville , Florida
24 Carbonized Grey, Bap, Lux ,GSX S750 also 50mpg
All a thief has to do is by the same as you, all those sockets are the same
CAMAVERICK
Chet
Long Beach California
2023 Maverick Tremor Lariat, 2021 Santa Fe Limited
Thought I would share my experience in trying to find just the right wheel locks for my recently acquired 2024 XLT that I ordered with the optional (64V), 17" machine-faced, carbonized gray painted, alum. wheels with Falken Wildpeak A/T tires.
The open-ended, non-chrome plated, steel wheel lock kit that Ford offers as an option for $75 just didn't fit with the aesthetic of the nice wheel/tire package that I paid extra for, so I looked elsewhere. My online researching led me to wheel locks by McGard and Gorilla that I thought might satisfy.
MCGARD
The vehicle application guide for McGard listed a few options for either chrome or black finished 60-degree cone seated locks in the M14 x 1.5 thread size which is what the Maverick uses. The McGard locks utilize a unique "flower pattern" keyed head lug nut and corresponding socket. I chose Model No. 24215 which are a closed end type in chrome finish. I thought these would look good in conjunction with the OEM lug nuts that my truck came with. These however proved to stick out like a sore thumb. When installed they ended up sticking out much more than the other lug nuts. The ends of these locks are flat and did not look anything like the remaining 4 OEM lugs on each wheel. I thought that someone with a pipe wrench could easily grab onto the protruding ends and torque these off. The cone seat on these was also about half the size of the OEM lugs which gave me some concern as to their strength in light of the potential for off road activities and towing in my FX4/4K optioned rig.
GORILLA
I then looked up Gorilla Automotive wheel locks. Gorilla didn't offer an application guide, just a 2021 catalog to download. After going back and forth through the many pages of charts in the catalog I ordered up a set of 4 of their Model No. 71641N wheel locks (M14 x 1.5 in chrome). These appeared to have a better looking head more in tune with the OEM Ford lugs, and they seemed to be not as long as the McGard locks. When these came, I realized that they had the same smaller cone seat as the McGards. I went ahead and tried them on for yucks. They indeed looked much better and did not appear to protrude as much as the McGards even though they’re about the same length. I however was again concerned about their strength given smaller cone seat.
After further scrutiny of the Gorilla catalog charts and other online info., I finally decided to try a set of Gorilla Model No. 96641DX "Factory Style" locks. These had the same head and length as the previous Gorilla locks, but have a “bulged“ cone seat similar to that of the OEM lugs. When I put these on they looked good and provided a similar sized seat diameter in comparison to the remaining OEM lugs. The length on these is still somewhat longer than the OEM lugs but due to their end shape and size they are not wrong-looking like the McGard locks.
One thing I noticed when putting on the new wheel locks, the OEM lugs on all my wheels seemingly were only torqued to about 80-90 lb. ft. from the factory. The Maverick Owner's Manual calls for lug nuts to be tightened to 148 lb. ft (200 Nm). I retightened all my lugs and new wheel locks to the recommended specs. and will recheck them after driving around a bit. Suggest others may want to check their wheel lug torques.
Here are a few photos that document my wheel locks journey.
Wheel with McGard wheel lock, not so good looking:
Wheel with Gorilla No. 96641DX Factory Style wheel lock that I ended up using:
Side by side comparison left to right Ford OEM lug nut that came with truck; Gorilla No. 96641DX Factory Style wheel lock that I ultimately used; McGard No. 24215 wheel lock not used:
Preferred Gorilla No. 96641DX Factory Style wheel locks, starting at around $33 US:
Where I got mine:
Amazon.com: Gorilla Automotive 96641DX Chrome Factory Style Wheel Lock Set (14mm x 1.50 Thread Size, 4-Pack) : Automotive
I currently have the McGard & I don't like it because it sticks out too far & looks funny. I'm switching to Gorilla wheel locks!! Looks way better!! Thanks for the info
realshelby
Houston
1969 GT 500, 1965 Mustang GT,
I have removed all the PITA wheel locks on my vehicles. Anyone that thinks they are secure has not seen a tool in action made to remove stripped nuts engage one of these "security locks".
JBEN110
Maverick Awd XLT tremor with lux
IMO wheel locks are useless. If someone targets your vehicle they are going to scope it out for locknuts first and bring the correct wrench on a battery impact. Gone in....about a minute.
The guys stealing wheels know exactly what to do - it's not like it's hard. There are only a few locking lug systems out there and it's easy to get the wrenches.
Besides, who wants to screw around with a special wrench trying to change a tire in the cold, dark and rain? And honestly I have never heard about anyone having their wheels stolen, but I have had to change tires at night in the rain.
you must not know anyone with a civic😂 i had 5 of my civic wheels stolen all together, then i put locking nuts on and never happened again, fyi they were black gorilla nuts, to be honest they didn't seem like good quality but they lasted 8 years so im happy with my purchase
RRaynor2
2022 Maverick Lariat
Those are very interesting. The concept of "tumbler" rings is novel. I couldn't find a set for the Maverick, but I wonder if the escape would work. I'm going to contact them.
I have the "factory" wheel locks and, like the OP, am disappointed in them. The video below all but proves they are security theatre as well.
BlueSpec1
Gene
My 2022 Escape lugs are M12 x 1.5 vs. Maverick M14 x 1.5
Decayed
yes
a car
Aren't civics of a certain vintage the most stolen cars? We had a 96 accord and the tuners loved them because they were easy to modify. Always afraid it was going to get stolen .
Automan21
Mel
‘23 XLT Eco AWD 4K Tow
Had a 97’ civic stolen right before my eyes. Insurance payed like $5k over what it was worth.
