Went to change cargo and 3rd brake light...
jphii
...bulbs to LED. The two outer screws in the housing came out fine. The 2 inner screws seem to be stripped, will not back out at all. Anyone had this issue?
See this thread...
Replacing third brake light and got a stuck crew. Any tips on how to remove it?
Palms
Gus
Jensen Beach, FL
21 Mercedes GLC; 23 Maverick Hybrid Lariat
Sorry. Replaced mine with no incident.
jphii
jphii
See this thread...
Searched and didn't see it. Looks like I'm taking it to the dealer.
Sorry, I screwed up link. Basically I think it was determined that the 4 screws go into plastic clips and screws broke retaining ear off. If I remember correctly someone managed to hold the clip from turning somehow and could back screw out.
Maybe finger under headliner? Most we going to dealer?
BobC
Freeport, IL
17 Impala, 23 Maverick EB AWD Lux 4K Fx4 360
The plastic insert clips had too much torque applied at the factory by the screws, and they stripped which you found. They will have to be replaced. Let the dealer do it under warranty. You could also try to get a small screwdriver head under the side lip of the screw possibly to lift it up and out while simo turning out.
Search for
"Replacing third brake light"
with titles only box checked.
Title has screw spelled as crew (???)
BlueSpec1
Gene
Zeno
Daniel
New Hampshire
2023 Catus Gray XLT
i have the same problem today, taking it to the dealer and it better be under warrenty
CurtisB
2023 Maverick XLT Hybrid
Get these at Homedepot. They come in all different sizes and will fit any hole and support any screw. You can cut it to the depth you need. Cheap fix and it will fit firmly in your original hole, or, drill into the plastic (carefully) and slip this in. It works and will hold your screw.
Ford Maverick Went to change cargo and 3rd brake light... 20240922_170136
Ford Maverick Went to change cargo and 3rd brake light... 20240922_170146
jphii
jphii
The problem is that the screws just spin, they don't come out.
First Sergeant
Fruitland Idaho
I agree, let dealer do it and get it done right. Thats what the warranty is for! That said I have used your method with the screwdriver hundreds of times over the decades and it does work most of the time. Use a small screwdriver and just easy tension while backing it out should do it! Old mechanic trick you and I remembered!
CurtisB
Use a small drill bit, drill the screw to bits, use a wall anchor to fill the hole.
