Weird failure to start
papak
Los Angeles
2023 Lariat Hybrid, CP360, Tesla 3, 1973 914 2.0l
The other night, we got in the car and coincidently turned on both seat heaters as I was pushing the Start button. Allmthe interior and exterior lights remained illuminated but I observed an amber "Check Engine" light as well as a red "Battery" light and The red "hybrid Battery" light above it. The car failed to start until I turned everything off and waited until all the interior and exterior lights went out. I then pushed the Start button and the truck started normally. I couldn't find any fault codes after the fact. No problems since.
I presume that the seat heaters and engine start were momentarily a bit too much for the circuitry. I replaced the original battery in December with a Delco AGM as a precaution. No problem registering it.
The Real Maverick
Jack
Nope.
Just a computer glitch.
Seat heaters take about as much power as (incandescent) dome lights. Less power than one headlamp.
Dr. No
Down South
2023 Maverick Hybrid
Nope.
Sir, I must respectfully disagree. The seats are heated by electric resistance heat. You cannot product that amount of heat over that amount of area with the same current that will illuminate an incandescent dome light.
Bob zimmerman
Northern <MN
25’ Maverick XLT hybrid AWD
I agree with the disagreement. For that amount of heat on a seat warmer I’m guessing more than 5 amps and that’s conservative.
A hair dryer on high is about 10 amps.
A toaster is about 6 amps
An incandescent 60 watt bulb is about a half amp. .5 amps
jonshep
SW Oklahoma
You are mixing AC and DC voltages. A 60 watt seat heater at 12 volts DC will require 5 amps. A 60 watt incandescent bulb at 120 volts AC will require .5 amps. Watts=Volts * Amps
Bob zimmerman
Northern <MN
Yes I am, and for reference only And for laymen. But my answers and yours are identical.
Bob- 30 years in the electrical industry.
The Real Maverick
Jack
That much wattage continuously is a lot of heat.
A soldering iron of 10 watts reaches 500°F over a small area. Seat heaters of 20 to 40 watts distribute 100°F over a larger area. And they are well insulated. Once the heat is applied, it stays there. (For a long while at least)
Heated seats typically draw about 3–4 amps (about 40–50 watts) per seat. As a reference point, a typical halogen headlight bulb is about 55 watts on low beam.
Dave O
New Smyrna Beach Florida
Looking for my “UGLY’S“ Electrical Book now?
With ignition key, Acc mode still on 12V system.
Do seat/wheel heaters kick on then?
If it takes a click to On before they do then never mind, the DCDC Conv is supplying power then.
I've never been one that does the key insert and instant sweep to Start.
Just wondering if relays are going off quick enough to support extra items on 12V system before HVB is supplying that.
It seems the push-button start would equate to that fast sweep method going instantly to Start.
Hmmm - possible to get the gear selector quickly to Reverse also to see what sort of fun that provides?
Dr. No
Down South
Sorry to evoke anger (in the form of an emoticon), but a halogen headlamp is not a dome light, as originally argued. I agree less than a halogen headlamp, but an incandescent dome light?
If you plug a voltage monitor into the dash power point and then turn key to on the led shows the 12v voltage for about 1-1.5 seconds before the DCDC comes online and shows it's 14 to 15.4 (or whatever).
The Real Maverick
Jack
Don't you remember the old ones that had 2 to 4 filaments per fixture and often 2 fixtures?
The Real Maverick
Jack
I do not believe the seat heaters kick on until the truck is "started". (Hybrid)
