Weathertech Mudflaps Installed
acapaldi
Andrew
I picked up a set of the mudflaps from Weathertech, got them installed today. Pretty good!
Install was easy, clips came out fine, they just screw on with J-clips. They include pre-cut vinyl strips to put where the flap contacts the paint, they do touch like the Ford set does.
Also happy to confirm that they fill the gap in the back left like the RokBlokz flaps do, good to see.
Ford Maverick Weathertech Mudflaps Installed 20221217_140940
Ford Maverick Weathertech Mudflaps Installed 20221217_141130
Ford Maverick Weathertech Mudflaps Installed 20221217_141007
Ford Maverick Weathertech Mudflaps Installed 20221217_141155
NJBob
New Jersey
Thanks I ordered the Ford ones with my. build. But took them off two weeks later I got a vin. Will look into these.
TopMavGun
22 Maverick
Does any part of these wrap around and touch the outside of the fender?
I read the Oem ford ones chew right through the paint. Pictures somewhere in this forum
acapaldi
acapaldi
Andrew
They do, they included little strips of clear vinyl to protect where they touch. Hopefully that works, I'll keep an eye on those areas for sure.
Hot Runr Guy
West Chicago, IL
Any chance to get a picture from the back of the rear ones?
Thanks, HRG
acapaldi
acapaldi
Andrew
Thanks, HRG
Ask and ye shall receive. Definitely like that they don't have the branding like the RokBlokz.
Also took a better picture of the overlap and vinyl, see if that is enough to protect the paint.
Ford Maverick Weathertech Mudflaps Installed 20221217_161559
Ford Maverick Weathertech Mudflaps Installed 20221217_141531
Ford Maverick Weathertech Mudflaps Installed 20221217_161618
Hot Runr Guy
West Chicago, IL
Thanks! HRG
gte105u
Katy, TX
Are they flexible enough to not impact ground clearance? Don't want to go over a big bump off road and have it rip off part of the wheel well.
acapaldi
acapaldi
Andrew
They're fairly rigid, but they are secured onto the metal tabs behind the wheel well liners. I'd expect the flap to give way before those did.
I'm FWD only, so I'm not going offroad anytime soon. The Rokblokz might be a better call if you're planning on doing that, those look flexible.
gte105u
Katy, TX
Yeah Rokblokz are probably better for me but damn they are expensive.
Paulyz
Paul
Forestville, WI
www.churchbelltoweradventure-suspense.com
I installed these Weathertech mudflaps as soon as truck arrived. They are excellent & fit/look great.
Paulyz
Paul
Forestville, WI
I installed Weathertech mudflaps as well, very good!
