volksnuts
volksnuts
Katy,TX
Maverick Lariat HPR
FYI the seat spacers I made moved it up about 2” to get the subs to fit down there
Ford Maverick volksnuts’ Lariat Maverick build IMG_1502
volksnuts
volksnuts
Katy,TX
Maverick Lariat HPR
I just secured a HPR Lariat hybrid. Just know I'm not copying you when my bronze wheels from my CG get installed! 🤣
I was afraid you weren’t going to go for Maverick #3
Welcome to the HPR (and 3 Mavericks) club
It is the best color
Vtec87pr1
Antonio
Virginia
youtube.com
2022 XL Ford Maverick
what kind of fog lamps you bought for yours i want to try them out
GPSMan
Many
An attempt was made, luckily I have a second set of speaker grills
Plan didn’t go as I’d hoped…. Figured I could just use a heat gun to deform the grills to go over the tweeters
Which technically they did but the covers a bowed a bit and look terrible up close
First time using a heat gun trying to reform some plastic
So I’ll leave them in for now, maybe I’ll have a better idea for the other set of grills
A) I don't think thats bad at all
but
B) could you take the grills off the hertz to make them slightly lower profile?
volksnuts
volksnuts
Katy,TX
Maverick Lariat HPR
but
I did not want to risk breaking them
The grills are not supposed to be removable (at least easily)
Still contemplating what I’m going to do about them
jewc75
Everything ive seen says the you shouldn't remove the grilles from Hertz tweeters. There is material that is part of the grille surround and removing it damages the tweeter.
volksnuts
volksnuts
Katy,TX
Maverick Lariat HPR
did you eliminate the light or just cover it with paint? How does it look at on if it wasnt eliminated?
No idea, I would guess the light output would be greatly diminished
My wife’s Bronco Sport I did differently and the light shines a bit around the edges, not enough to be seen while driving…. I just haven’t gotten around to removing the bulbs from hers
volksnuts
volksnuts
Katy,TX
Maverick Lariat HPR
Annoyed I missed the milestone
I guess I was still partially asleep
Ford Maverick volksnuts’ Lariat Maverick build IMG_1603
volksnuts
volksnuts
Katy,TX
Maverick Lariat HPR
@daddio211 I’ve got Hertz front stage with an Audio Control EQDX EQ
Not using the delay function
