Venerable Charcoal Canister
Ranch
Sacramento CA
2023 Marverick FX4 4K
Evap canister on the FX4 is protected. Ask me how I know. 😏
https://www.mavericktruckclub.com/f...ide-of-the-maverick-are-for.24406/post-457951
On buying parts at a dealer: I wouldn't recommend it. Get a quote, make sure you have the right part, then look online. You'll save yourself money 9 times out of 10.
Thanks for this. I was thinking about jacking up my FX4 to see if the canister was protected by the shield.
If you can get the right Motorcraft part number and buy it online you are getting an OEM part.
Some of the Dorman stuff can be a bit iffy. I would buy Dorman for jobs at the Ford Fleet Center I worked at when Ford had parts on forever back order.
  • Like
Reactions: bgn
skyhawk
Airplanes motorcycles cars SUVs
That's kinda scary, and there is a lot more vunerable 'stuff' under the hybrid:
yes, there are a lot of low hanging giblets and nothing to protect them but one's imagination. Quite a few others have also found this out the hard and expensive way.
Ranch
Sacramento CA
#me too.
I haven't been able to bring myself to paying Ford $750 to do this repair yet. This felt skid plate is a joke. Somebody please stamp some out of steel or sell us some rock sliders.
I'm going to try the fiberglass method of plugging too. I hope I can get the mounting tab back on their well enough to hold it for the foreseeable future.
Parts Dept. gave me PN LX6Z9D653F $459 for the evap canister
and LX6Z6775R $97.17 for the "under shield".
Service Dept. gave me PN NZ6Z 9D289 A $207 for the evap canister and PN NZ6Z 9B007 AA $45 for the "under shield".
Why the difference?
Service department wants $725 for evap canister replacement and $200 for under shield replacement.
O'Reily's website says they're $269 and special order...
Motorcraft Vapor Canister CX2660 | O'Reilly Auto Parts (oreillyauto.com)
I took the Motorcraft number you got from O'Reillys and got a link to RockAuto for the same part for $235.79. They even show the Ford part number which matches the number you got from the Ford parts department.
https://www.rockauto.com/en/moreinf...2MgMqFjAmO/soSJuwg44B+kyAw+rlv8da+aGW1P5u4rYI
fossil
ernie
ohio
funny thing is the evap on my F150 is in almost exactly the same location with not even a felt cover. made it easy to get at to repair mouse damage, threw an emissions code and I couldn't get new plates. once I repaired the wires it took 2 days before it would take a reset.
@davew, if you truck isn't throwing a code patch it if you can
rch75
Ryan
Found a replacement on eBay with the same part number for a “Lincoln Corsair”. The photos look the same. For $190, I’m going to give it a shot. My understanding is that fiberglass won’t permanently or chemically bond to the plastic Evap canister. It will just stick to it like a clamp or glue that will eventually rattle free. Once it does the check engine light will come on again.
I might try some stitching/sewing and/or adhesive on the felt cover though. That thing needs to be steel asap.
Ford Maverick Venerable Charcoal Canister 83B2BCEE-2C71-4548-B695-78B863EC6D32
rch75
Ryan
Found a replacement on eBay with the same part number for a “Lincoln Corsair”. The photos look the same. For $190, I gave it a shot and it’s an exact fit!
Truck has run another 25K miles with no problems.
jmk63
North Bend, WA
2025 Maverick XLT
Oh boy.... Mrs hit a road gator (tire casing) on the highway and cracked open the vapor canister. Got a replacement from LKQ for $119+tx (<6k miles on canister), but darn it I cannot figure out HOW to get the large hose pipe off the existing damaged canister. The two smaller lines I figured out, but the large one...? No clue. Any suggestions would be helpful. Thanks -
jmk63
North Bend, WA
2025 Maverick XLT
Whoops. Nevermind. LARGE black connector is a side squeeze and pops off. Now to go back to LKQ and tell them their part interchange system doesn't work for this canister. <sigh>
Djrobinson
Wichita, KS
2019 Buick Encore
$850!? I'd glass up that old one and make it extra thick on the bottom.
I just had mine replaced due to a road hazard. The cost was $1060 installed. Insurance covered $40. 2022XLT.
