UPDATE Side steps / running board for 2024 Maverick hybrid
NewcMaverick
Kyle
Indiana
Cruze
Are you sure it’s not the technique you’re using to get in and out? Yes, I’m a little taller than average, but I get in and out of my fx4 with 2” lift and 31” tires like it’s nothing. And that is 4” taller than the stock hybrid height.
Yea I'm 5'6". I assume OP is very over-weight (sorry not sorry, how much you weigh?)
Maverick_JohnMcCain
Maverick_JohnMcCain
Scott
South Florida
Edit: Here’s a little food for thought. I used to have this Jeep Wrangler Rubicon. It had a 4” lift kit, 1” body spacers and 38.5” tall tires. So that is 8.25” taller than stock. No running boards. No problem getting in and out. You use the door sill as a step instead of adding a running board and compromising ground clearance.
WOW
Oh Brother
I never would have thought that somebody would question how I get in or out of a vehicle.
Phimosis
Larry
Santa Clarita, CA
WOW
Oh Brother
Well, you did say, “I'm destroying the outer edge of the seat every time I get in and out of the truck. My legs are not long enough to reach”.
I’ve known dozens of short-legged, petite “soccer moms” over the years that drive SUV’s that sit higher than the Maverick hybrid does. None of them had side steps for their SUV. None of them were tearing up their seat getting in and out. Using a little logic and problem solving, the question naturally arises; what is it that you are doing differently than everyone else that is causing this problem? Is that you turn a full 90 degrees, then slide down the seat edge to the ground with both feet at once? Seems like that would tear up the seat. But I don’t know, because I’ve never gotten out of a car like that.
So yes, maybe it IS your technique.
Aguy
US
bicycle
Not too bad, there are 2 or 4 squigley bolts on each side for the hybrid that take a little work getting in
Looks really good! I like it. Considering adding them to help the little ones get in and out...
DiverUtah
Layton, ut
2023 Maverick Lariat Hybrid Cyber Orange
They definitely help for my little guy
Realtruck
Diamond Sponsor
Realtruck
Ocala FL
My hybrid
These are especially nice for that little bit of added drop to get in and out. Are these the Ionic or Steelcraft? They look great on your Maverick!
gzebrick
Guy
Memphis, TN
25 Lariat AWD Hybrid 4K towing, '24 ioniq 6 limited AWD, '91 BRG Miata 5spd
Those look good. I’ve a 25 lariat on order. My wife has mobility issues so adding a side step could help. Do they weigh much? Thanks.
commadorebob
I'm in the camp that I don't understand the need in a truck you sit down into. But I am also in the camp that it is your truck and do what you want.
this is the best setup I've seen.
Phimosis
Larry
Santa Clarita, CA
Not everyone sits down into the truck.
Agreed. The seat height is 23 5/8” from ground level. Anyone with an inseam of less than 24 inches won’t be able to “sit down” into this full sized sedan with a cargo bed. Looking at mean anthropomorphic data of inseam to overall height, anyone that stands less than 4 feet 4 1/2 inches won’t be able to “sit down” on the seat, at that seat height (the mean height of 8 year old males and females).
Personally, I think it would be safer to just supervise and assist your small children into and out of the vehicle, rather than buying expensive side steps that may also pose as a safety hazard to your children, without supervised assistance.
