Recently purchased TAC Side Steps Running Boards for my XL Hybrid.
Amazon.com: TAC Side Steps Running Boards Compatible with 2022-2023 Ford Maverick/Maverick Hybrid Pickup Truck 3" Stainless Steel Side Bars Step Rails Nerf Bars Off Road Accessories 2 pcs : Automotive.
After reviewing the instructions (attached), and getting under the truck, I'm a bit confused on the final configuration. At numerous points during installation, it talks about fitting the supports without fully tightening, marking the outlines of the supports, then removing the rocker panel molding and cutting away the marked areas. Since the panel clips are permanently removed, and the supports won't be contacting the molding, what holds the molding in place after installation?
If anyone has installed these or similar nerf bars, can you help me understand how this works? There are no videos that I know of that cover complete installation, and I find the instructions lacking in some parts.
Any help is appreciated. Thank you.
