*Update* Dead truck Part 3-Battery/Drain/Charging Epic fail
Nw_adventure
Salt Lake city
Have an Eco/boost that's already had a couple power modules and the actual battery replaced with a 760 CC/AMP AGM some months ago, now over the weekend the battery has completely drained twice Saturday/Sunday night even after a 3 hour freeway drive with no accessories plugged in etc and dead again this morning-
Anyone else find a long term solution to not having these electrical issues from re-occurring ?
wax87
Stuart
Dallas South
2004 Avalon
I thought this was a Hybrid only issue
TedTX
Ted
San Antonio TX
MICHELIN ML0728 Power Source XR1 Portable 1000 Amps Jump Starter with Air Compressor and 400 Watt Peak Surge Power Inverter and Bluetooth
https://a.co/d/gHafI79
This helps my hybrid. It fits snugly upright under the back seat. In hybrid it can be setup in jump mode and just use the built in switch.
Ford Maverick *Update* Dead truck Part 3-Battery/Drain/Charging Epic fail IMG_0795
Nw_adventure
Nw_adventure
Salt Lake city
Have an S/Type jump unit and although fully charged it would just give an error message. Luckily while camping a friend had another charge unit or I would have been SOL - New unit arriving today and then another dealer appointment -(
Rojo
NW, Louisiana
XLT, Alto Blue, AWD Eco-Boost, Lux
This is the first I'm hearing of Ecoboost having battery issues. What does the dealership say when you took it in for repair?
TedTX
Ted
San Antonio TX
Don’t trust lithium ( older type) in hot storage… you discovered why the hardest way/ like I did. They just don’t have the power even it 100% if the thing is stored in hot area. The jumpbox I use is large and heavy from AGM battery, and can be back charged with AGM battery based 12v system like Mavericks so used like a secondary battery/ pass through for A/C and 12v DC needs.
Nw_adventure
Nw_adventure
Salt Lake city
The issue was a defective S/type charger- The 2nd unit (exact same model) jumped the Maverick in two seconds-
TedTX
Ted
San Antonio TX
Will it after the second Summer stored in vehicle?? Lol, glad it was covered as defective, must be a good brand.
i will wait til a LiFe battery are more common in those devices before keeping one in vehicle all the time.
Got a tiny Jackory power station I baby by keeping it out of the heat To keep it alive longer.
Nw_adventure
Nw_adventure
Salt Lake city
I got this instead -
AstroAI S8 Car Jump Starter, 1500A Portable Car Battery Charger with Wall Charger for Up to 6.0L Gas & 3.0L Diesel Engines, 12V Portable Jump Box with 3 Modes Flashlight and Jumper Cable(Orange) https://a.co/d/5AMe33m
Nw_adventure
Nw_adventure
Salt Lake city
Yowsa- Going from bad to worse here- Left the dead truck all day on the battery charger, came home and started no problem. Let it sit for just 30 minutes and it's now completely dead ! How can a fully charged battery go dead in 30 minutes ? Nothing is attached- Just wow
TedTX
Ted
San Antonio TX
Wow, check the engine…. Are you sure they didn’t slap a hybrid engine system instead. Yes with drain to beyond dead happen to me. Since its so bad can you recharge to start and safely drive to dealership?
30 mins has to be a record for any Maverick!
icegradner
British Columbia, Canada
2022 XLT Maverick Hybrid
That sounds like a nightmare. I hope your state has good lemon laws.
Nw_adventure
Nw_adventure
Salt Lake city
Barely. Limped it to the dealer 30 minutes ago -
PNWMaverick
Pacific Northwest
2022 Maverick Hybrid - RIP
First time hearing this on an Ecoboost.
Parasitic drains are an absolute nightmare to track down on a vehicle. In a lot of cases it is impossible from a practical point. I have seen manufacturers (Ford included) buy back newer vehicles with a parasitic drain that couldn't be resolved.
About the only way you can find these issues are by...........
  • Checking every ground point on all the wiring harnesses and sub harnesses.
  • Check all the individual connections at every point of every harness.
  • Check continuity and resistance on every pin.
  • Visually inspect every inch of the wiring harnesses, looking for pinches, punctures, and kinks.
  • Disabling and enable systems/circuits on the vehicle while running and monitoring it to look for anything that is out of specification.
Even the slightest short, anywhere, can cause these issues.
As I said, in practice the above is impossible as the cost to have a technician do this (warranty or not) is just incredible. You have to basically disassemble the entire vehicle in order to do the above.
Your issue could be as "simple" as a compromised wire because of a pinch under a seat, or floor. A slightly loose ground or connection can be the cause of it.
