Truck Stuck in Deep Sleep Mode
mhw21zap
23 Maverick Hybrid XLT
I left my Ford pass connection active. I like having the remote start and I get alerts if my perimeter plus alarm has been set off. I did turn off Wi-Fi in the truck settings.
Still no deep sleep after over a month of resetting the BMS. I just added a kicker hideaway under the rear seat. I'll see if that affects power draw.
[/QUOTE
Hello - may I ask how you were able to turn the WiFi off in truck settings? I have a 23 Hybrid that's experiencing some similar issues.
Penasco
2019 Outback, 2005 Tundra DC
Y'all need to make sure when you charge these batteries, it is connected so that the BMS sensor captures the current flow. Typically, you want the negative to be connected to a ground and not the battery terminal. There are YouTube videos about it, like this one (rather long and uses an F-150 as example, but the idea is the same)
If you have a trickle charger connected on the battery side of the sensor, it will never see that current.
How do you recommend using a trickle charger on the hybrid with the battery being under the rear seat?
