Thank you! Now I need to convince my dealer to actually do it.You should have gain settings come up when you press the buttons whether the trailer is there or not.
For anyone else stumbling across this thread it’s TSB # SSM 50917
My dealer did a software update on the instrument cluster, fixedThank you! Now I need to convince my dealer to actually do it.
Possibly. The tech I spoke to suggested it was as simple as the 4K software patch not being uploaded onto the cluster at build. If the patch could be found I would think it could be uploadedWonder if using forscan could fix that issue.
That's the problem these days, mechanics almost have to be computer techs to fix these issues (good thing I am).....
There is a beta 2.4 version of FORScan that that can write firmware to modules. I have updated some of the modules in my 2010 Fusion with it. But be warned, it is beta and I bricked a module with it once and had to purchase a replacement moduleWonder if using forscan could fix that issue.
Attach tester to line-out from controller to hitch, it should light up when brake pedal is depressed.Anyone know how to test the trailer brake controller without a trailer"?
