TPMS issues
CurtisB
2023 Maverick XLT Hybrid
Same here, I get a warning when my tires go below 30psi.
Brett3550
Brett
WI
Velocity Blue XL
Just disable them in FORScan and call it a day. We've been driving decades without them and they are more of a headache than what they are worth.
Anybody experience this, almost daily notification from Ford Pass that I have tire pressure problem but no indication on dash that there’s an issue?
Tire pressures always check out good at 35psi.
Is there an easy check to see if each individual tpms sensor is good or am I stuck with the dealer, just thought I’d ask before I go to the dealer. Thanks Ken
Get a quality digital meter that reads in tenths of a pound and verify how close the dash figures are to the digital readings.
Not much chance of me seeing dash notification again as I check pressure at least monthly or when ambient temp is around 12°F from when I last aired pressure up or down. Also when I get in mine I put truck into ready and immediately push mode button 3 or 4 times put knob into R or D and push go pedal. Then I can look at dash and most of screens have cycled bye bye so I have missed any blinking TPMS and only see the steady dash light. The ice comes on usually pretty quick due to the 10% power wanted trigger.
Shelbyv8
JD
I run 37 or 38 lbs, because at times we have 30-40° change in ambient temperature in 24hrs.
Mini One-Fiddy
Jax, FL
'23 Bronco Wildtrak. '23 Maverick XLT BAP Hybrid
So this resets the tpms sensor in the wheel?
There is a unique sequence of pressing the brake and turning the ignition that puts the vehicle into a learning mode. It then instructs you to go to specific corners and press the button near the valve stem to relearn the sensor.
Automan21
Mel
‘23 XLT Eco AWD 4K Tow
Ahh ok I see now .
I did change wheels and bought the correct mhz sensors but they won’t program with the regular sequence of letting air out at the proper times notified by the dash.
A.Bursell
Stanwood, WA
I didn't have to do any type of relearning sequence or anything. Just programmed the sensors and the truck picked them up. Not sure when you would need to put it into learning mode or anything.
Candoman
Ken
Ingersoll
2003 Maverick XLT Hybrid
I do and they will be going on the truck probably in a few weeks as the white stuff is coming soon but this problem only just started about 2 weeks ago so?
Thanks everyone for your input I’ll post when I find the solution.
TPMS follow up
Put on my snow tires that have my original Ford rims and sensors, haven’t had any issues since.
Problem appears to be with the aftermarket TPMS sensors I had fitted when I purchased my new rims!
