Tow Brake Controller Quandry
bluesteel
Jerry
Bergland, MI (U.P.)
2022 Maverick Lariat
Help, please, from experienced tow-ers!
My trailer is a 2,300 lb conventional travel trailer. It is a single-axle with electric brakes. I towed it well over 5,000 miles with the Mav last season, with no issues other than not-great gas mileage due to the high profile. I do have the 4K tow package.
The problem for most of last season, and now, is braking. I don't think the integrated controller is applying the force it should be. I have the gain turned up all the way and don't feel much force when applying the truck brakes, regardless of my speed, either through normal application or by using the manual lever. If I'm coasting maybe 15-20 miles an hour and apply the manual lever, I only get sort of a leisurely slow-down. I can't get anywhere near locking up the trailer wheels or even an abrupt pull-back by the trailer.
I have owned aftermarket proportional controllers on other vehicles in the past and know how they are supposed to function and feel. I know an integrated controller should feel somewhat different from the aftermarket versions, but THIS much different?
Early last season, soon after buying this trailer, I adjusted the trailer brake star wheel as far as it would go to increase braking force. In a normal world, I shouldn't have had to do that, either. Braking was better (still not great) for awhile but seemed to gradually "wear off" over the course of the season.
I was resigned to this being a trailer brake problem and was planning to bring the trailer in to get diagnosed right about now. Then I had someone else tow it out of storage to a pickup location for me. He is driving a larger Ford pickup with integrated controller. He said the brakes have no problem at all and he could easily lock them up (on gravel). I don't think the difference would be attributable to his having a larger pickup - I assume (?) brake controller output wouldn't be much different on a big wheel than on a 4K Mav? (Though his may have options for boost and such...)
So, I brought the Mav AND trailer to my local Ford dealer on Monday. It is a small-town dealer with a good reputation, not known for BS. They tried everything out and said the controller is functioning normally - this is how the integrated controller should feel, and it's different from the old ones. (Whether old ones referred to the really crude and cheap time-based controllers, or proportional controllers, or both, was not stated.) Supposedly the best service guy was put on the case, and the guy who appeared to be the head of the service dept. also looked at it himself. They were able to lock up the brakes on gravel but said it shouldn't even be possible to do so on asphalt, unless the Mav brakes are also locked up (which itself is also nearly impossible). (Note: I don't particularly WANT them to lock up on asphalt, but it seems like they should be able to get close when the gain is at 10!)
They seemed to think it was normal that the brakes are behaving this way even though the gain is turned up to 10. I asked why there's even a gain control and a manual lever if that's the case, and the guy said this is because people like to feel like they have control over it. ???
My main real-world concern in all this is the truck would not be capable of significantly slowing the trailer in the event of an emergency.
I am perplexed. Any thoughts?
Jeff D.
Duluth, MN.
Jerry, I would be as skeptical as you. I've towed campers with electric brakes and with vehicles with built in controllers and have not had brakes as underwhelming as you've described.
I would think a shop that often deals with electirc brakes could figure out if the controller is putting out adaquate voltage and current.
I would get another professional opinion, if I was in your shoes.
Good luck. :)
Joe Strummer
Squamish, BC
2024 Ford Maverick XLT Tremor
Let me know the outcome. I am in the process of having a dealer brake controller installed on my Tremor.
bluesteel
bluesteel
Jerry
Bergland, MI (U.P.)
Does that mean whatever controller the dealer chooses to install aftermarket, or is it possible for them add the integrated version?
bluesteel
bluesteel
Jerry
Bergland, MI (U.P.)
Good luck. :)
I did have somewhat similar experience with a Tekonsha controller on a previous vehicle. I had the trailer brakes looked at, even the shoes and magnets replaced, and none of it made a difference. Controller was putting out correct voltage. Finally I replaced it anyway, and suddenly everything was fine, other than the many hours and hundreds of dollars wasted. My conclusion in that case was the controller probably was not putting out correct current (amperage). I have a clamp multimeter but don't know the procedure and wiring I would have to do to test that myself. I would like to think the dealer's equipment would check for this issue, but then maybe they had confirmation bias and didn't even go that far? I had to pay them $90 (in FordPass points) for diagnosis :mad:
Raymundo76
Ray
Mesa Az
21 Mazda CX-5
Good luck. :)
Good recommendations.
RRJJINTN
Robert
Tennessee
2022 maverick lariat first edition awd
[/QUOTEthere was a recall on trailer brake controller,did dealer do it ?
bluesteel
bluesteel
Jerry
Bergland, MI (U.P.)
Trailer brake controller recall - is this the one that held up sales of Mavs with the tow package several months ago? Or was that for Mavs with the regular tow hitch only? I only vaguely remember it.
Mine is a '22 purchased in December 2022 and I think manufactured the month prior. So if it's the recall I'm thinking of, it did not apply to my mfg date. I will look into it again, though. My Ford account shows no outstanding recalls and I never got a notice for any TBC recall.
Jeffr4JC
22 Maverick Lariat Fx4 w/4k tow in Carbonized Grey
I also have the 4k tow and tow my almost 4k camper all the time. I keep my controller on 8 and it stops me on a dime. If I set on 10, it locks up the trailer brakes on gravel. Sounds like your controller isn't working properly. That or the trailer's brakes need replaced (not just shoes but springs). Let us know when you find out what it is.
Blessings!
bluesteel
bluesteel
Jerry
Bergland, MI (U.P.)
@Ford Motor Company any chance you can help out here? It seems highly likely here that what the dealer is telling me is not accurate. I would go to the other area dealer for a second opinion, but then I need to pay another diagnostic fee. I have the factory extended warranty (I'm JUST past the basic manuf. warranty) and thus if possible do not want to go to another shop.
RRJJINTN
Robert
Tennessee
safety recall notice 22s17/nhtsa recall 22v193 2022 maverick “trailer brake controller may not properly apply the trailer brakes” i got it in the mail for my eco boost 4k
Hot Runr Guy
West Chicago, IL
Hot Runr Guy
West Chicago, IL
If it was manufactured in Nov 2022 it would have been a 2023 model.
HRG
RRJJINTN
Robert
Tennessee
mine was purchased dec 9, 2022 built in 2021 & i got the recall in the mail for trailer brake controller..
