Totally Bonehead Move
Is this a bonehead move by Ford or "Safety Feature"?
  • Bonehead move
  • Legit safety measure, not just "sounded good on paper".
Results are only viewable after voting.
RLader
Royce
Fort Payne, AL
2021 BB Bronco Sport
Sorry old boy, you are mixing fact with fiction and ages old recollections.
A) turning the key off has never ever locked the steering wheel. Try it. You'll prove me right. It must be in park to lock the steering.
B) turning the car off in drive created "engine braking" say if you lost brakes on a hill; as taught in thousands of schools.
How soon knowledge is lost.... 😢
B) Not on automatic transmission.
JimParker256
Cedar Park, TX
Sorry, but I believe you're incorrect on that point... The Maverick uses engine braking (both hybrid and EB) to maintain the set speed when using cruise control. Ditto for 99% of the "full-size" trucks with auto transmissions. My '15 Chevy Silverado 2500HD Diesel explicitly called this out in the manual (for both the Diesel and Gas engines) as "recommended" when going downhill with a load.
Ranch
Sacramento CA
2023 Marverick FX4 4K
What about with the engine off? That's what the claim is.
GPSMan
GPSMan
Many
More so with the engine off.
Engine on, it is possible to be getting an idle amount of fuel, generating small, but greater than zero horsepower. It is also possible to generate zero horsepower in some makes and models and hybrids probably do have this capability but not all pure gas engines do.
GPSMan
GPSMan
Many
Engine braking works by restricting airflow. In a vehicle with a gas engine, if the cylinders stop receiving air and fuel, but the engine’s spinning parts continue to rotate, the pistons keep trying to suck air into the cylinders but end up working against a vacuum because the throttle valve is closed, allowing very little air into the system. As the pistons pull against this vacuum, they slow down; this has a braking effect from the crankshaft through the transmission and on to the wheels.
LSchicago
Lloyd
IL
I don't know how old you are.
It was taught in Driver's Ed classes way back, to turn the key off if you are having a fire, loss of brakes, steering, or other major malfunction, for example.
Well if you turn the key to the off position on an old vehicle while driving it will cause to lose brakes and steering. No reason to do that really. Stop, then key off. Common sense is no longer common.
GPSMan
GPSMan
Many
I think you missed the point. 🤣
Gotta read the whole thread for context.
LSchicago
Lloyd
IL
I did. And still have no idea why you'd turn off the key while still driving. It has been posted here that removing the key sets the shifter to park. Ruin the transmission to avoid 3 seconds of the engine running? Sure why not. Then blame Ford for the IDIOTIC behavior.
Dslaughterbeck
Duane
It stops idiot kids from ghost riding your Ford.
Jman79
North East, USA
Many questions and statements here revolve around:
- How it used to be
- How it should be
Sadly, new cars systems are more intertwined than ever and that's not changing. There are also too many possibilities outside "normal use" for engineers to account for all of them.
So as drivers we're going to have to adapt and realize we may have to change some behaviors. Think of some of these old methods as happy work around vs "the right way", then find new work arounds.
Most of what's being suggested is solved with a simple "don't do that" because they are weird exceptions to how most use vehicles.
Some like "in case of engine fire while doing 70mph on highway" well turning the engine off wasn't guaranteed to help.
Hate to say it... But it's all about #s and odds are this feature will prevent a lot of loss and a lot of injuries. If you're an outlier who needs it different you'll be deemed not worth it by the bean counters and lawyers.
OP: for the "why not 0 mph"? I work in software and usually it comes down to...
- No Time/money to fix something that isn't even really a bug, more of an oversight.
- There is an argument against that supporting doing it at 3mph that they've seen and we don't.
Both mean it likely isn't changing 😟
GPSMan
GPSMan
Many
Right before the truck goes over a cliff.
