Torque Vector RDU Fluid Change
Chops
Lobo
Torque Vectoring RDU fluid change today. 14 months & 2,200 miles on the this first change of fluid…
Pic 1:
Up on the ramps
Pic 2:
Same bolts for fill & drain. Attach directly to a 3/8 socket wrench.
Pic 3:
Fluid a bit dirty as expected. Lots of Crud on bolt magnet & was dome shaped - indicating no more crud was being attracted to magnet? Took many wipes to clean crud - but I replaced with a new plug anyway.
Pic 4:
Clean fluid in the pump ready to go in.
About 26-28 ounces came out & 31.5 ounces back in. A trace of the 32 ounce bottle ended up on cheek/lips/glasses. Wear safety glasses if you’re going to be underneath truck like I was:)
Fluid did not overflow from fill hole when I finished filling. I could feel the fluid just below the hole however. Stated capacity is 1.1 quarts for this RDU btw.
My next fluid drain & fill in 2 years. I drive 80% Sport / 20% Lobo modes. My RDU is always spinning!
Ford Maverick Torque Vector RDU Fluid Change IMG_0662
Ford Maverick Torque Vector RDU Fluid Change IMG_0663
Ford Maverick Torque Vector RDU Fluid Change IMG_0665
Ford Maverick Torque Vector RDU Fluid Change IMG_0666
lavaspill
One quart was enough for my last Tremor 24. I believe same RDU as your Lobo. Haven’t done the 26 Tremor yet I wonder if something changed.
shadow_munk
Lobo
I asked my ford dealer last time i was there to check mine and they said they had to drop the exhaust to get to the bolt, is that true?
Chops
Chops
Lobo
Do you have the Tremor or the Lobo? I have the Lobo - the fill plug is a pain to loosen & tighten due to lack of enough clearance to ratchet your wrench…
See pic#2 in my OP. The plug connects direct to the 3/8 socket wrench. Not too hard to get the tool into/onto the bolt - but very little clearance to ratchet the tool. I was struggling even to move one click at a time. 50+ clicks was tiresome.
The socket wrench bumped the RDU on one side & the exhaust pipe on the other. I have an aftermarket exhaust & I did loosen a clamp to push the exhaust pipe a little further away. Was able to get 2 clicks at a time instead of just one…
I do remember thinking that the OEM exhaust probably was designed to give more clearance…apparently not!
Anyway, the OEM exhaust is all one piece - from catalytic converter to the tailpipe. “Dropping it” means popping it out of a couple of the hangers. Not a big deal - maybe 5 minutes tops. Would make it easier to loosen/tighten the plug for sure. But the service advisor was being a bit dramatic on the labor involved!
edit…circled in red where the fill hole is. It is near the top of the RDU - you have to get your tool up there to access. There is not a lot of room to ratchet your tool without hitting a bump on the RDU & the exhaust pipe.
Ford Maverick Torque Vector RDU Fluid Change IMG_0771
