Torque Converter Lockup
TDawg
Travis
Wisconsin
2022 Maverick XLT 2.0
Is anybody else having severe engine lugging around 30-40mph on a 4k tow package equipped maverick? I had a regular ecoboost maverick and once in a blue moon would it lug but nothing like the maverick I currently have. Is it the different gearing in the 4k equipped models?
icegradner
British Columbia, Canada
2022 XLT Maverick Hybrid
My understanding is that the units with 4k towing do have a different gear ratio than the non-tow package models.
LM42
Luke
Phoenix, AZ
Maverick XLT FX4 EB
They have a shorter gear ratio, and would be less likely to lug. Clutch lockup should not cause that unless you are under heavy load and it does not come OUT of lockup for some reason. I have 4k and have not had that issue.
icegradner
I was just answering the OP's question about whether or not it had a different gear ratio. Not saying that was the cause of his issue.
LM42
Luke
Phoenix, AZ
Maverick XLT FX4 EB
For sure. My reply was mostly to him
TDawg
TDawg
Travis
Wisconsin
Ok that makes sense. A trip to the dealer is in order. The transmission wants to shift to the highest gear possible and the rpm’s drop to like just above 1k and it has a severe vibration.
Ford Motor Company
Official Ford Account
Dearborn, mi
TDawg
TDawg
Travis
Wisconsin
3FTTW8F90NRB11008, Gordie Boucher Ford, the problem is I can’t get an appointment for like two weeks
LakeCamelot
Danno
Wisconsin
Jeep Wrangler and F150
I've noticed the same thing here with my 2.0 eco FX4 and towing package. The odd thing is I noticed it shortly after delivery back in March 2023 but seemed to go away in summer. Now that it's colder here I have again noticed it. Switching to tow/haul mode in town when at these 25-40mph speeds solves it, but at the price of extra fuel usage.
I've been using premium 91-93 octane since delivery.
ndmiller
Noah
Atlanta
2024 Maverick XLT Azure Blue Metallic
Still waiting for my truck but I thought regular was all that was needed in both Hybrid and Ecoboost. Why use premium?
In GA it's $0.20-$0.40 more expensive....reason for the question.
Zero issues with my awd 4k tow so far, not even a squeak or rattle, not a single recall, pray it stays that way. Hope your dealer can remedy the issue soon, good luck
ndmiller
Noah
Atlanta
87 is fine for a hybrid or the ecoboost. Ford recommends a higher octane rating for best performance or under certain other conditions.
So funny trying to download the 24 manual on the other thread.
Thank you, in my mind 2.0L Turbo=91, I was skeptical of the 87 anyway.
LakeCamelot
Danno
Wisconsin
No real reason for the higher octane usage other than the many different opinions. Some say 87 is good enough and others stating 91+. The extra cost isn’t a biggie to me coming from a 20 yr old F150. Also only drive about 10k per year.
but otherwise I have about 7,000 on it and runs and drives great (other than the lugging at low speeds at times ) I did need the recall for the trailer towing wiring. Had brake/turn signals but no night time clearance lights.
Blitz-Hacker
Account Deleted
Hugo
I have a 2024 Eco 4K tow Lariat with 35K miles and my Maverick will every once in a while drive weird. It feels like my 1988 Toyota 4x4 when I left the front wheels locked in on dry pavement. Kind of like something is putting a strain on the motor with slight vibration. It happened yesterday. The first 20 miles of my trip was rough riding and then it went away and this is why I was searching for it today. I did come across a thread that a Ford tech stated that he has replaced more than a few transmissions in Mavericks and it because the torque converter went out first causing the transmission to eventually fail. I sent him a note asking if he had any symptoms before his tranny gave out but he has not responded yet. Does anyone here know what symptoms you would have if you had a faulty torque converter? Can the dealer tell when a torque converter is going bad?
