BClubb352
Brandon
Ocala, Florida
2023 Ford Maverick Hybrid
!!MINOR MODIFICATION OF PARTS REQUIRED!!
I purchased several ladder racks from Amazon and only kept the one that required the least modification to work and look decent. Also measured every tool box in stock at Lowes, Home Depot, Tractor Supply, and Rural King. Here's what I settled on:
Ladder Rack: VEVOR 46-71 inch 800 lbs capacity
This item is currently out of stock on Amazon and also the manufacturer site, but that may change in the future. Contact them for more info.
I chose this rack due to the style and size of the angle braces. Check the photos below and you'll see why that was important. Also, Pay VERY close attention to the adjustability of the height AND WIDTH of whatever racks you are buying. Very few will work on a Maverick without even more modifications than I had to do.
Modifications required to work with a tool box, and on a Maverick:
1. Removed 3-1/2" from the bottom of the "T" shaped sections so it wouldn't be insanely tall. I would've liked to do even lower, but that would mean sectioning and re-welding the bent parts. At that point I would've just made new racks from scratch
2. Drilled and welded new nuts further up the "T" section, because step 1 cuts them off. If you can't weld, you could also use large self-tapping sheet metal screws, or drill entirely through the connection and use a nut and bolt to fasten the pieces together.
3. Cut 2-3/4" out of the lower angle brace for the front rack (to accommodate a toolbox).
4. Cut 1-1/4" off 2 of the backing bars that go under the bed side rail.
5. Grind/sand/repaint everything, and replaced the included hardware with black set screws instead of bolts.
Tool box: Delta Mid-size crossover truck box 1-304000
Mine is branded Crescent JOBOX, but they're all made by Delta. I'm sure others will fit the same way, just compare measurements.
I had to drill new holes for the mounting clamps and also a relief hole for the rack clamp bolt to sit in. (photos below)
Bedliner: Line-X standard. Installed by my local Line-X shop for $575.
Slightly shorter antenna will be delivered tomorrow so I don't run into any clearance issues there (stock antenna ends about 1" above the rack.)
Ford Maverick Tool box, bedliner, and ladder / kayak / lumber / whatever customized rack installed 1
Ford Maverick Tool box, bedliner, and ladder / kayak / lumber / whatever customized rack installed 2
Ford Maverick Tool box, bedliner, and ladder / kayak / lumber / whatever customized rack installed 3
Ford Maverick Tool box, bedliner, and ladder / kayak / lumber / whatever customized rack installed 4
Ford Maverick Tool box, bedliner, and ladder / kayak / lumber / whatever customized rack installed 5
Ford Maverick Tool box, bedliner, and ladder / kayak / lumber / whatever customized rack installed 6
Ford Maverick Tool box, bedliner, and ladder / kayak / lumber / whatever customized rack installed 7
Ford Maverick Tool box, bedliner, and ladder / kayak / lumber / whatever customized rack installed 8
Ford Maverick Tool box, bedliner, and ladder / kayak / lumber / whatever customized rack installed 9
Ford Maverick Tool box, bedliner, and ladder / kayak / lumber / whatever customized rack installed 10
Ford Maverick Tool box, bedliner, and ladder / kayak / lumber / whatever customized rack installed 11
Ford Maverick Tool box, bedliner, and ladder / kayak / lumber / whatever customized rack installed 12
Ford Maverick Tool box, bedliner, and ladder / kayak / lumber / whatever customized rack installed 13
Ford Maverick Tool box, bedliner, and ladder / kayak / lumber / whatever customized rack installed 14
Ford Maverick Tool box, bedliner, and ladder / kayak / lumber / whatever customized rack installed 15
Ford Maverick Tool box, bedliner, and ladder / kayak / lumber / whatever customized rack installed 16
Ford Maverick Tool box, bedliner, and ladder / kayak / lumber / whatever customized rack installed 17
Ford Maverick Tool box, bedliner, and ladder / kayak / lumber / whatever customized rack installed 18
Ford Maverick Tool box, bedliner, and ladder / kayak / lumber / whatever customized rack installed 19
JBryant
Jesse
Bowie, TX
I take it Mr. Mav has to work for a living and not just sit in a garage or driveway all day and be a lazy butt. Great job and sure the Mav will make enough to pay for your parts and labor. Looks factory made.
BClubb352
BClubb352
Brandon
Ocala, Florida
YEP! Most of my tools get dragged around in a box trailer that stays on the job, but I keep basic hand tools in the truck, and need to be able to go get pipe, trim, studs, etc and transport 2 kayaks on days off without a trailer. :)
JBryant
Jesse
Bowie, TX
Now I really feel sorry for Mr. Mav. He does not even get a day off and has to work so you can enjoy your days off. I have a lazy one that stays in the garage most of the time since I am about retired. Winding down my remodeling business and hope to be totally retired in about 4 months. Most of what I do now is administrative, not on the jobsites. I know the Mav will give you many years of dependable service.
TedTX
Ted
San Antonio TX
It all fit, it all fit! Its a Maverick miracle!
Great job, may have to show it’s possible. My plumber next door neighbor is on the fence ( not literally) about getting a hybrid Maverick for his work. The size limits are the largest concern. So whenever a good pipelike carrier system is made for the Maverick I tell him it’s possible, and he shouldn’t wait to order a Maverick
  • Like
Reactions: Dad
Dad
Thanks for taking the time and effort to research and share a rather major modification. No doubt, you've given many the confidence to go ahead and tackle this on their own as well as saving them the same time and effort and avoiding costly mistakes. Great post!
Dad
I don't know which is more fortunate . . . you having a Maverick or a plumber who lives next door.
TedTX
Ted
San Antonio TX
He charges full rate = expensive! Neighbor or not, and advice isn’t free, unless he offers it ( I wait for his brats, beers and smokes events he gets talkive and offers free advice)
TedTX
Ted
San Antonio TX
Ok, he did fix our outdoor faucet bib after the week long ice age super hard freeze on his own. Since plumbers where going for the highest payer first.
He apologized, for fixing it without asking. But he was concerned about where the water was coming from. It may been hiding his damaged pipes.
Never had a plumber apologize for not charging.
Bruce8858
Bruce
2024 Maverick Hybrid
Good write up and links. Reasonable prices on the items you bought. I liked all the photos you provided. Never ceases to amaze me at all the different things you guys find to do to your truck.
maverickeric
E
NJ
F150 + Maverick XL
Looking for a bed rack right now - any reason this vevor wouldn't work? vevor rack
I'm generally unsure about the mounting options. I want something sleek and 17" high max, with the option to bring it up if needed. I have no issue cutting metal to modify a rack.
Also considering the yakima knockoffs that are all over amazon. Local seller is selling one for $350 and it looks like it would work.
