Thumping feeling in my wheel tire/lower front left!!!!!!!!!
catinthebathtub
haas
houston
66 GT 350, 60 VW, 34 pickup and porsches....
So I have had a thumping in the lower left wheel area. It has been looked at by 2 ford dealerships and my own work which is an auto shop. Only one person has felt it other than me. I say that's only because they don't daily drive it to know a difference. No one has been able to find the issue
i currently have the lane assist feature set to "Alert". i believe i have felt it "alert" me several times without provocation. it feels as you describe your thumping.
TSAINTS1115
" When lifted and accelerating I don't feel anything as if its gone "
So removing the load from the suspension and drivetrain makes it go away?
Any other time when driving (truck has load on suspension again) it returns?
Tires rotated and it does the thump on all regardless?
Is the "thump" constant or does it increase with rpm?
My guess would be to check the bearings from the hub through to the trans where it receives the halfshaft.
Ford Motor Company
Official Ford Account
Dearborn, mi
So I have had a thumping in the lower left wheel area. It has been looked at by 2 ford dealerships and my own work which is an auto shop. Only one person has felt it other than me. I say that's only because they don't daily drive it to know a difference. No one has been able to find the issue and I'm starting to get very pissed. I want it fixed because it annoys me so much. I would LOVE ANY HELP. Seriously anything. Anyone at ford have any insight.
Everything that's been checked.
1. Tires have been rotated
2. Majority of bolts have been checked to see if they are loose
3.When lifted and accelerating I don't feel anything as if its gone
PLEASE HELP !!!!!
Hi there! Would you send us a private message with your VIN and dealership name and location? I’d like to look into this concern on my end.
ShadowBlack XL440
Robert
Northern Ohio
I saw another report of a failed axle shaft. A bad CV could cause the noise as noted.
NeedForSteve
Eastern NC
2007 Fusion 2.3; 2023 HPR XLT EB
Just off the hip, sounds like a binding CV joint.
ShadowBlack XL440
Robert
Northern Ohio
PLEASE HELP !!!!!
Any luck resolving this issue? Determine wast the source of the noise was?
PortlandME
Portland, Maine
Probably unrelated, but I've noticed if I drive with my left foot flat on the floor (not sure why I do this sometimes - I guess to stretch in a different position), I feel something thud against the bottom of my foot from underneath every once and a while. Almost feels like something kicks up and hits the underbody, or something is flapping up and down from underneath (nothing visible when I look). It's pretty noticeable / alarming when it happens, but since I don't have my foot in that position very often it isn't that bothersome and I haven't bothered looking into it further :unsure:
Nighowl2000
Roy
Ottawa
2022 ford Maverick lariat
Does it make a noise? Can you record it?
Rob Cactus Gray
Robert
Sierra Vista AZ
11 Prius
Is this problem constant?
Can you post a video?
Are we looking in the right spot?
What alterations have you made?
I had an 08 Altima that clicked on every turn. No one could figure it out and it ended up being a lose bolt that attached the door (drove me nuts 🥜).
trying to get the beat here
thump, 1, 2 thump
Thump thump thump thump thump
Thump-pity thump thump . Your car is Rudolph
check trailer hitch (if applicable), sway bar link, inner/outer tie rod ends, half shafts on both sides, exhaust system is secure.
Can you post photos of the under side? I don’t have a truck 🛻 to go look around
tomahawk72
Travis
Westbrook, Maine
22 Maverick XLT
Mine is doing the same thing, moving and randomly when stopped and idling. I tried taking a look but it has a plastic cover under that side. Heading to the dealer on Friday for an oil change and asking for that to be looked at.
tomahawk72
Travis
Westbrook, Maine
22 Maverick XLT
