Third Brake Light Replacement
pa4ul
Earth but a small spot in texas to be exact
1973 Ford F-100/2025 Maverick Lobo/2015 Mercedes CLA Sport Plus
I cracked my third brake light housing and I'm curious is there any difference in ford third brake lights? Most of what i see on the internet for replacing shows it wont fit the maverick but the assembly looks identical on almost all fords.. Can anyone confirm if there is a difference in the lens from an f-150 to a maverick please.
John,
Why not replace it with an oem?
What are you looking for different?
I do like this all LED replacement for the F-150 third brake light.
Ford Maverick Third Brake Light Replacement 20251007_122103
  • Like
Reactions: Dad
CNJFF
NJ
As far as I know the Mavericks share the same assembly as the 150s. That's why it looks oversized. Unless something changed for '25/Lobos.
Quick look at Amazon:
"Full LED High Mount Third Brake/Stop Light Assembly Compatible with Ford 2015-2020 F-150, 2017-up F-250 F-350, 2019-up Ranger, 2022-up Maverick"​
"3rd Brake Light Replacement for 2015-2024 F150 LED Third Brake Cargo Light Replacement for 2017-2024 F250 F350 F450 F550 Super Duty / 2019-2024 Ranger / 2021-2025 Maverick"​
I remember some aftermarket ones (like the one I bought) come with the "wrong" plug but shaving down the alignment extrusion on one side solves that.
pa4ul
pa4ul
I just need the lens, not interested in an aftermarket light or replacing the whole assembly. I can find f150 oem replacements for under 50 and for some reason the only ones i find for the maverick oem or oem looking are north of 100 dollars. Just curious what makes our cost so much more or what the difference is if any.
Sticks
St. Louis
Waterick
Laurens county SC
Isn't the lens sonic-welded to the housing? Even if you could source the lens only, it will be much easier to swap full assemblies.
The Maverick uses the same part (and part number) as base model halogen 2015-2020 F150, 2017-2022 F250.
https://www.ford.com/product/high-mounted-rear-lamp-p4000078816
Might find one on a wreck in a salvage yard, that's many years to choose from. At least on the F-150's. Super Duty's much fewer I'm sure.
Phimosis
Larry
Santa Clarita, CA
Ford Maverick Third Brake Light Replacement IMG_4478
gjallen3
Jerry
Arizona
2024 Maverick XLT
John,
I love the idea of the strobe for the 3rd brake light only, but I wonder if it’s legal in all states. It only flashes three times and then is constant. Enough strobing to get the attention of drivers behind you and not be distracting. Makes perfect sense but some state laws do not allow red or blue strobing of any kind so as not to confuse your vehicle with law enforcement.
Aleks
Aleks
West Coast
I'll sell you my oem one I took off my 2025 lariat if you want. I replaced it with a morimoto 3rd brake light.
Jerry,
If you are worried about it don't buy it.
My third brake light flashes three times then stays on.
I installed it hoping to attract attention to when I'm stopping.
Daveinva
Washington, D.C.
2025 Maverick Lariat Eruption Green
IME, this is one of those things that A) no police officer will ever pull you over for alone, B) a real jerk of an officer who stopped you for another reason will "enrich" your ticket with a citation for the flashing brake light, and/or C) if you have a mandatory safety inspection, you might fail it on account of the flasher.
I didn't care about any of those things, because I'm far more concerned about being rear-ended. And after 20 years of experience installing aftermarket brake flashers on my motorcycles, swapping bulbs for LED flashers was a no-brainer for me.
P.S. Plenty of states have stupid laws that are almost never enforced alone. For example, Maryland makes it illegal to wear earplugs while motorcycling. I break that law every time because I refuse to ride without earplugs because protecting my hearing matters infinitely more to me than my wallet, not to mention the law is nonsensical since you actually hear BETTER at speed with plugs in. Of course, MD cops would never be able to pull you over for wearing earplugs for obvious reasons, but they could slap you with an added fine if they ever did pull you over for something else.
Same difference with flashing brake lights.
