The First Cold Air Intake on a 2.5 Hybrid Maverick!
TheGriffin1313
Mongo
San Diego
22 Mav, 05 M3, 07GSXR
Wait,.. you can Forscan it to make it use more battery than gas???
Can it be done? using Forscan to make it use the Battery to higher loads? Can the battery warranty be voided if Ford found out?
SpaceCowboy
2022 Ford Maverick Cactus Gray
The ONLY benefit you will gain from a CAI in this model will be noise. You may even lose performance.
GPSMan
Many
A lot of people are trying to boost MPG.
A few are trying to lower MPG. 🤷🏻‍♂️
TedTX
Ted
San Antonio TX
Why would you want to lose capacity and lifespan of hybrid battery to tweak another 10% of battery usage? Cost wise doesn’t add up over life of Truck.
mavmav
Walter
New York
Maverick Hybrid 2022
Doubtful they could do something even more complex like engine airflow design
Of course ford did "great" airflow design by drilling holes in skit plate and removing partially front grill air shutters after engine fire recall! What a shame. it is easier to drill holes vs. fixing fuel leakage problem.
Wnbasac
Louie
Calif
Honda CR-V & firebird T/A
Ok, am i missing something 0-60? I’ve got my 70’s Trans Am for that. May I suggest investing in a 60’s-70’s muscle car if you wanna be Fast and Furious
Daniel
The Woodlands, TX
1998 Ford Ranger 2.5L 2WD XLT Standard Cab Manual
Crap, they couldn’t even design their own stock mudflats properly so they wouldn’t eat into the paint they “protect” within a few months. Doubtful they could do something even more complex like engine airflow design.
What about this product? - Spitfire’s FlexForce
Claims to:
increase horsepower by 15%
10% more torque
Increases throttle response
10-25% less fuel
https://www.ebay.com/itm/3851409992...o56ukxssjo&var=&widget_ver=artemis&media=COPY
Daniel
The Woodlands, TX
If a bit of bent tin delivered such a drastic increase in fuel economy then OEMs would be implementing instead of all of the extra microcontroller effort for Start/Stop to the benefit of 2% fuel savings.
Milous
WA State
2022 XLT Alto Blu, LUX, Sunroof, delivered 3/18/22
Claims to:
10% more torque
10-25% less fuel
Notice the asterisk next to all the claims - "UP TO".
0.0 falls into the "Up to" claim - and that number is probably very accurate,
GPSMan
Many
Claims to:
10% more torque
10-25% less fuel
You read it WRONG.
It literally says "15-25% MORE FUEL" (will be used).
It's snake oil. But they are trying to imply it is a cheap turbocharger.
Your vehicle needs a consistent air/fuel ratio to burn correctly. So by adding more AIR you gotta add more FUEL and more fuel COULD lead to more horsepower in the right setup.
Ford Maverick The First Cold Air Intake on a 2.5 Hybrid Maverick! CFBD143E-C2A1-4866-AAF1-8C7098D19CBC
Daniel
The Woodlands, TX
You read it WRONG.
