Tailgate spray on bedliner touch up
dove hunter
Charles
25 Maverick XL. 24 Palisade Calligraphy NE
So I had my bed and tailgate sprayed at the dealer, turned out great. I ordered a rear tailgate shock and part of the install is removing a black metal plate. I am sure after removing this plate, it will be the color of the truck. So my ? Is, is there any aftermarket spray to touch this little 1x1 space with the stuff they use to spray bed liners. I was thinking of going to the dealer and seeing if they will touch it up for me. Thoughts? Thanks.
dove hunter
Charles
Was thinking herculiner? But not if it will match what they sprayed.
Carlitos_92
I have no clue what was originally installed on my truck because I bought it used, but I do know it isn’t the Ford product. I bought a can of the Herculiner spray and it worked fine. It did take many coats to build up the same thickness, and I pressed 60-grit sandpaper into it when it was tacky to create “texture” to match the rest.
Edit: that was over a year ago, and it has held up fine.
raymaines
Ray
Tacoma, Washington
Alto Blue Lariat Lux Hybrid
I'm thinking you're over thinking this ultra minor problem. Put it all back together and drive on. Seriously,
