Subwoofer install troubleshooting
MLC2023
MLC2023
Peter
Boston, MA
2024 Maverick XL
The easiest way to tap the fronts is to pop the climate controls panel off, and the plugs are right behind it. Super easy to get to. That panel just pops right off if you pull it straight back. Then you can get one of these little guys, so you don't have to cut a single factory wire : https://www.crutchfield.com/p_541LPHFD31/PAC-LPHFD31-LocPro-Advanced-T-Harness.html?omnews=18429741
On another note, I'm thinking that enclosure is quite a bit too small for the sub you're using. You're not going to get much low bass from that. I'm not trying to be a downer, but rather trying to temper expectations. I would try to get more air space for that sub for sure with a little larger enclosure.
I'll also whole heartedly agree with the Forscan Flat EQ change!!! You won't notice the difference on factory speakers, but you will absolutely notice on a subwoofer. It is a cake walk to do, since it is in easy mode. I hope that helps!
Thank you @rallyshark . The woofer is rated for .25ft. The box is more like .23. I put a little poly fill in. This is my first sound mod and I’m definitely a novice. I’m afraid to commit myself to tapping at the head unit ā€˜cause then I’ll have to thread the speaker wire. We’ll see.
MLC2023
MLC2023
Peter
Boston, MA
2024 Maverick XL
KeithVi
Keith
Toyota Camry SE
Ford Maverick Subwoofer install troubleshooting 1000006708
Best audio upgrade I've ever done to any vehicle.
Allowed me to feed the tweeters in a way that I am able to equalize and amplify. Provided a subwoofer output that I'm able to amplify an equalize.
Rob911
Rob
2023 Maverick XLT
I tapped the rear speakers for my sub amp and it worked without any problems. It appears that bass is only cut to the rears when you use the option that selects the driver as the listener and not all the passengers.
kkreit01
Korey
Olathe, KS
'22 Maverick, '17 Grand Cherokee Limited 4x4 V6
I also tapped my front signals behind the climate controls. I cut the connections, and used M/F quickconnects. My amp is powering the front door speakers + sub. Guarantee those rear 4" speakers aren't seeing a full-range signal. They can't handle low frequencies.
MLC2023
MLC2023
Peter
Boston, MA
2024 Maverick XL
Embarrassed to say the problem was the sound settings were set to ā€œDriverā€ instead of ā€œAll Seats.ā€ I was sure I had done this and thought it had to be something more complicated. Big difference. First tune was ā€œComfortably Numbā€ which sounded great. I still may tap the front speakers and get a Forscan adapter but those are projects for another day.
Carlitos_92
I think the "All Seats" setting probably improved the sound, but it can still be better. The main issue is that the rear speakers are cheap 4" drivers and Ford chose to use signal processing to ā€œenhanceā€ the system sound and then capacitors to protect the speakers from the ā€œenhanced sound.ā€ If you're throwing any money at all at a Maverick stereo, you really want to eliminate that extra manipulation. Especially if you're putting third-party DSP in as well.
(Edited for correctness; I originally had it wrong about the capacitors…)
jewc75
Try unplugging one of the rcas, left ot right channel.
AVC
North Texas
'23 Maverick Hybrid XLT, '02 Ranger, '20 Pilot
I’ve got my subwoofer taped to the rear pillar speakers as I’ve read about here on several different posts. I’ve got sound, but not a lot of it. Even with the volume all the way up. Any suggestions?
Oops, maybe this doesn’t go in rigs. I’ll repost an electronics.
For XL or XLT systems, you MUST change the Forescan EQ to "Flat EQ" to have any usable LF signal below 55Hz on ANY of the speaker lines (front or rear) you intend to tap for the subwoofer.
The default Factory EQ setting RAPIDLY rolls off below 55Hz to ALL speakers; basically no signal in the subwoofer range that is usable.
wvpc
SE Michigan
2016 Subaru Outback 3.6, 1999 Mazda Miata.
AVC,
Did you connect both rear speakers to your sub or only use one of the speakers leads? Can I get away with just using one set of rear leads and get adequate sound out of my Rockville SSP8 sub?
Thanks.
MLC2023
MLC2023
Peter
Boston, MA
2024 Maverick XL
AVC,
Thanks.
@wvpc You’ll find many who say you can get away with only tapping one side. I tapped both left and right ā€˜cause I knew I would be disappointed with some of the alt rock and other eclectic music I listen to where you get a base line from one side only.
AVC
North Texas
AVC,
Thanks.
Both rears go to sub, as the LF content can vary song-to-song; may be somewhat to hard panned L, R or be centered in the mix.
It's straight forward to get to the L and R rear speaker wires at the respective rear door sills. I used T-taps and 22ga stranded wire.
https://www.amazon.com/Wire-Connect...pcontext&ref_=fplfs&psc=1&smid=A31E7B3UFJ5DLK
AVC
North Texas
Note that when you do the Forscan "flat eq" setting, the "Driver" head unit mode becomes identical to "All Seats" (no measurable change between them).
MLC2023
MLC2023
Peter
Boston, MA
2024 Maverick XL
Thanks @Miguelinfest how does it help? Does it boost the output?
Hi @Miguelinfest , I was able to fix my problem (embarasingly I did not set the sound to all seats). But I still may keep the remote. Did you run it to the front seat? Or did you leave it in the back? If you ran it to the front seat where did you run the wire?
Miguelinfest
Miguel
Orange County
2024 Ford Maverick Iconic Silver Metallic BAP
I ended up running it through the front. Went behind the dash. If I had the part I recommend to you, I could have ran it through the rear speakers. Wish I would have known before I hand, but either way I wasn’t getting a strong enough signal.
