Steel vs aluminum wheels - weight, handing, mpg?
j1truck
San Jose, CA
EGolf
Hi All
Is there a noticeable difference between steel and aluminum wheels in terms of weight, handing, mpg when pair with hybrid engine?
looking to get xl but heard somewhere that steel wheels are not good for mpg, handling, etc
thanks
JohnDLG
South Texas
In theory aluminum should weigh less. I've also heard that given weight increase at the wheels would cost more than the same weight as payload. I'm not sure how that works out in practice though.
PapaDave
North Seattle
Maverick XLT FX4 VBlue & XLT hybrid A51
I was looking at aftermarket wheels and noticed a few aluminum wheels, same size, were approximately 10 to 20% lighter than steel wheels.
Gary in NJ
NJ
Too Many Subaru's
A lighter wheel takes less power to rotate/accelerate. A higher unsprung weight makes the suspension work harder. Lighter is always better, unless strength is compromised.
Oh, and steel wheels scram “I’m cheap”.
Ronaldo
Ron
Los Angeles
71 bronco, 67 conv Mustang, 93 RX7 R1
I agree Gary. Also The advantage to steel wheels is know by every police department in the US, aluminum cracks with a big impact and steel will bend and still hold air most times. I was going to go XL but for 2,285 you get great looking wheels and Interior, cruise, few other goodies, and resale.
ColoradoShooter
Colorado
Tacoma/Fusion
Lighter weight wheels have less rotational inertia and therefore mpg, acceleration and handling all increase. But, factory aluminum wheels need to be strong enough to handle curb impacts and pot holes, so there manufactured thicker than aluminum race wheels so they’re still “heavy”.
MAVRICK
Any
2024 XL
Or conversely scream: "I'm common sensically, proudly value orientated" - Depends on one's own value system ...
Snax
North America
Yep, I’m not one who needs to impress strangers by spending money. Many other things to do with it.
black dog
Charles
Louisiana 71449
2017 Ram 2500, 2000 Jeep Wrangler
Come on. Opinions are like A**holes, everybody has one.
JsnMrd
2016 Honda Civic Touring
So does the hybrid mpg rating takes into consideration of the wheels? Is that why they're only advertising XLT mainly?
Value and mpg are the two main things I look at as my deciding factors in getting this truck so I gotta make sure I nail it!
grumpyunk
tom
georgia
Personally I find the steel wheels attractive. I think they send the 'no-nonsense' message to anyone who looks at them. They seem purposeful, not here to mess around or look pretty, but to get the job done.
I only would go for the XLT to get cruise control, unavailable otherwise. Adding an aftermarket cruise to a drive-by-wire throttle seemed a bit questionable to me.
tom
fbov
Frank
Bushnell's Basin
2020 Escape Hybrid
Hi All
Is there a noticeable difference between steel and aluminum wheels in terms of weight, handing, mpg when pair with hybrid engine? ....
So does the hybrid mpg rating takes into consideration of the wheels? ...
The discussion of handling and vehicle dynamics is spot on, but a hybrid drivetrain changes a couple things regarding mileage.
Weight is demoted to a secondary effect by use of regenerative braking. It's not perfect, you only get 85-90% return, but that's enough to knock a 10% effect down to 1%, which can be ignored. I had snows on steel wheels for the C-Max. I saw no change in mileage when changing over in Spring and Fall.
Wheels matter because of the tires you put on them. Rolling resistance is important, and low profile is better, but it's far more important to mount a LRR tire regardless the rim choice. .
j1truck
San Jose, CA
EGolf
I ordered an XL. Most of the “factory” aluminum wheels don’t have much advantage. I’m happy with steel wheels.
Would checking the car side sticker of xl and xlt be able to tell us of the weight difference?
