Skinny and tall - why not?
Shouldn't be a problem in spare location as long as wheel AND TIRE 😇 diameter is under 29 1/16" with hitch or 29 5/16" without hitch.😁. of course a 22" wheel will fit without its tire or even with its airless band tire!
Sjurgen
Shannon
Oregon
Chevy Spark, Toyota Prius, 1973 F100
So just to clarify. Having a wider tire isn't so much a problem at the pinch weld? And a front lift doesn’t help with the pinch weld contact ? It’s the increased tire diameter that is the only culprit to the pinch weld rubbing?
LSchicago
Lloyd
IL
Not Crazy. When my current 225/60/18's wear out, I'll be looking to go with 235/65/18's to keep skinny, but gain height/lose wheel well gap.
The vast majority of 235/65/18 are much heavier 6+lbs than stock 225/60/18. The 225/60/18 primacy 24lbs was introduced in that size, I believe for 2022's. To get a decent selection 17" wheels are better, might even get 215's for a 17" wheel.
Wow this looks like option for 215's on 17".(I did not check it's rim width req.).
PRODUCT INFO
Bridgestone Dueler H/L 400
Bridgestone Dueler L/H 400
Equip your crossover or SUV with the Bridgestone Dueler H/L 400 for luxury comfort and outstanding highway control. This premium all-season tire delivers confident year round handling, comfort and security. Other features include:
  • The Bridgestone Dueler L/H 400 is an all-season performance tire for crossover and SUV drivers who want versatility, long wear, all-season traction and comfort.
  • This tire is also designated with the “highway luxury” (HL) title, meaning it delivers exceptional performance and a sophisticated design.
  • Available in 17’’-21’’ diameters, the Dueler L/H 400 is a popular replacement for OE tires on vehicles such as the Subaru Forester, Toyota Highlander, Infiniti FX50 and other 2WD and 4WD light and medium-duty vans, pickups, SUVs and crossovers.
  • This tire is run-flat optional, meaning in the event of tire loss due a puncture you can drive for up to 50 miles at 50mph.
  • This high-end tire has an all-season tread pattern, featuring circumferential grooves to remove water from the tread, reducing the risk of hydroplaning.
  • The tire compound is engineered for confident handling and braking, allowing you to make turns, lane changes and other meanuevers with ease.
  • For additional confidence in everchanging weather, this option is designated with the M+S rating for mud and light snow traction.
  • For optimal treadwear, performance and tread life, it comes with a tread depth up to 11/32” so you can get more out of your tires.
  • Bridgestone backs the L/H 400 with a five-year Workmanship & Materials warranty.
Want to protect your tires against everyday road hazards? Don’t get caught unprepared, add our exclusive Certificates in your cart. We guarantee they’re the best tire warranty in the industry.
read less
TIRE SPECSTIRE SIZES
UNIFORM TIRE QUALITY GRADE (UTQG)
Treadwear300
TractionA
TemperatureA
SECTION WIDTH 215
ASPECT RATIO 70
RIM DIAMETER 17"
OVERALL DIAMETER 28.9"
RIM WIDTH RANGE 5.5" - 7.5"
WEIGHT 27 LBS
TREAD DEPTH 10"
LOAD INDEX 100
LOAD RANGE SL
MAX PSI 44 PSI
SPEED RATING UP TO 130 MPH
SIDEWALL DESC. BLACK SIDE WALL
VPN 142469
GTIN 092971193676
LSchicago
Lloyd
IL
In my case, the Toyo Observe gsi-6 225/60/18 are 31# each. Going up to a 235/65/18 in the same tire is 34#, a 3# difference. Not much of a difference. But improved ride and looks for a slight MPG penalty is a tradeoff I can live with.
On the plus side several brands are releasing their new tires and are coming up with options in 225 & 235 sizes with lower rolling resistance compounds, tried, etc. Michelin defender 2's look pretty good. They did not come up on my search though. Maybe our options will improve soon.
Sjurgen
Shannon
Oregon
Great great thread. If I can only find an 225/70R17 (yet to be successful), I would do it in a heartbeat. 225/75R17 - me waiting for a braver soul to try it out and report back.
Hello everyone! I can attest that the 225/75r17 Hankook Dynapro AT2’s do indeed fit my FX4 without a front lift without any pinch weld manipulation. Your welcome!
hdave
Toronto, Canada
'23 Alto Blue Maverick XLT
pics!!
Wilbur
Scottsdale, AZ
1967 Ford F100
The highest profile I could fit under the stock, no lift 23 hybrid was the Yokohama Geolandar H/T G056 at 225/75 R17.
They clear the aftermarket mud flaps by 8 to 9 mm.
Ford Maverick Skinny and tall - why not? Complete R
I like the look post mpg every 5k miles and any associated wear problems.
hdave
Toronto, Canada
more pics from different angles please?
what was the hit to MPG? (easiest way to tell is to find out how much of a hit you took to miles per tank)
Sjurgen
Shannon
Oregon
Ford Maverick Skinny and tall - why not? IMG_1083
Ford Maverick Skinny and tall - why not? IMG_1082
Wilbur
Scottsdale, AZ
1967 Ford F100
Front
Ford Maverick Skinny and tall - why not? Front
Rear
Ford Maverick Skinny and tall - why not? Rear
Profile
Ford Maverick Skinny and tall - why not? Profile
Full
Ford Maverick Skinny and tall - why not? Full
After I got them home from Discount Tire, I hit them with some inexpensive tire cleaner / shiny stuff from the discount rack at O'Reilly's.
The next day I washed the tires off, then wiped them down with 303.
If you live in the desert and want to maintain some shine to your tires, this combination is a good option. I have to say that these Yokohama tires take a shine even better than Michelins.
Sjurgen
Shannon
Oregon
Front
Rear
Profile
Full
Ford Maverick Skinny and tall - why not? IMG_1087
Ford Maverick Skinny and tall - why not? IMG_1086
hdave
Toronto, Canada
thank you both!
