Just bought a used Lariat Tremor and noticed the tailgate isn’t locking with the fob. Quick google search seems like the XLT and up should have this feature. Anything I should check? Thanks
Camera works fine. I’ll have to try and find the panel you’re talking about. I don’t think the gate was replaced, seems like the original Ford spray in liner but I’ll look closer.The first thing I would look for is if the plug on the harness that connects the tailgate to the truck is connected properly. Is the rear cam working correctly? If yes, then I would open the panel on the tailgate and see if the lock actuator is connect (and there). Maybe the original owner had to get a new tailgate and did not move the actuator?
37k haunless the truck has more than 36k miles you're under bumper to bumper warranty, just take it in and have it fixed.
If your lucky, maybe the original owner did not like the tailgate locking so he simply disconnected it?Camera works fine. I’ll have to try and find the panel you’re talking about. I don’t think the gate was replaced, seems like the original Ford spray in liner but I’ll look closer.
I’ll find out in the morning!If your lucky, maybe the original owner did not like the tailgate locking so he simply disconnected it?
There's a panel on the inside of the tailgate when you open it it's about 5 ft long 1 ft wide and has eight torx screws in it. Remove that to make sure the connector for the tailgate lock actuator is connected.
If it is and it's not working still then take it to the dealer and have them see what's wrong with it.
