Should a 2023 Lariat Tremor have power locking tailgate?
Starship
Alex
Oregon
Lariat Tremor
Just bought a used Lariat Tremor and noticed the tailgate isn’t locking with the fob. Quick google search seems like the XLT and up should have this feature. Anything I should check? Thanks
NedF
BC Canada
Was a '23 now a '24 Lariat Lux
The first thing I would look for is if the plug on the harness that connects the tailgate to the truck is connected properly. Is the rear cam working correctly? If yes, then I would open the panel on the tailgate and see if the lock actuator is connect (and there). Maybe the original owner had to get a new tailgate and did not move the actuator?
Starship
Starship
Alex
Oregon
Lariat Tremor
Camera works fine. I’ll have to try and find the panel you’re talking about. I don’t think the gate was replaced, seems like the original Ford spray in liner but I’ll look closer.
colinl
Colin
ICT
unless the truck has more than 36k miles you're under bumper to bumper warranty, just take it in and have it fixed.
Toddman45
Todd
St. Louis, MO
There's a panel on the inside of the tailgate when you open it it's about 5 ft long 1 ft wide and has eight torx screws in it. Remove that to make sure the connector for the tailgate lock actuator is connected.
If it is and it's not working still then take it to the dealer and have them see what's wrong with it.
NedF
BC Canada
If your lucky, maybe the original owner did not like the tailgate locking so he simply disconnected it?
Starship
Starship
Alex
Oregon
Lariat Tremor
I’ll find out in the morning!
jdonnery
New York
jdonneryphoto.com
If you’ve gone that far, you might as well fix it yourself. Start with making sure the lock is getting power with a meter.
WJOHNM
New York,LI
My 22 XLT FX4 LUX locks, do Tremors come with luxury package??
Starship
Starship
Alex
Oregon
Lariat Tremor
Mine should have it. The window sticker was left in the glove box and it is listed on it. I’m curious if he actually did replace the tailgate now because it doesn’t have a Tremor sticker on the gate. I’m waiting for the weather to clear up this morning to go investigate.
Jimmyland
Pennsauken, NJ
2023 Ford Maverick
My 2023 Lariat EB Lux has the tailgate power lock working. I would assume yours should too unless it was disabled
