Rust prevention spray coating worth it?
Notontime
Ken
2023 maverick xlt
Wondering if rust sprays are worth the price.
Bob The Builder
Butch
Vermont
If installed correctly, yes. Lots of plastic and felt to remove plus the taillights. Holes to drill in the doors, cab corners and remove plate on the tailgate to spray inside that as well. My quote is $550.00 USD and the shop need the truck for 2 days.
nklem
Norm
Coast of Maine
2019 and 2022 Hyundai Ioniq Electrics
Yes. I simply “fluid film” (NH Hydraulics back to black recently,Undercoating) my cars every few years. Yes it works, it’s only about $25 worth of product per vehicle and it takes 30-45 Minutes under it on ramps. I do inside all frame members, behind all wheel wells, suspension, members, inside door drains, rocker drains and corners. Completely coat the underside. I also paint any bare parts (driveshafts etc) with rustoleum. It works, is cheap and worth the money and effort..
Some garages only charge $150-200 to do this service. They do not get into the inner doors etc, but better than nothing.
Ford Maverick Rust prevention spray coating worth it? IMG_1470
Ford Maverick Rust prevention spray coating worth it? IMG_1471
Old Fart
Mid Florida
2022 Ford Maverick XLT; 2016 Prius ECO
I used 2 cans of vinyl spray undercoat but I live in FL and don't drive on the beach. Used high temperature paint on the exhaust system to make it look good while melting from the inside out.
Bertram
Charles
Indianapolis, IN
2002 Ford Ranger, 2017 Transit Connect Wagon
Just remember when you have aftermarket rust inhibitor like Zeibart it will void your vehicle warrenty as pertaining to rust. My dealer informed me of this because they will drill holes to inject the rust inhibitor.
linerguy
mark
WI
2024 eco maverick lariat 2020 escape
If I remember correctly you have to have cancer eating an actual hole in the sheet metal before they will fix it, not just rust or bulging paint. With Zeibart that doesn't happen. Here in Wi I think it's a must.
OpieGoneBad
Pennsylvania
2022 Maverick XL Hybrid, 2023 Maverick XL Hybrid
I'm a fan of Fluid Film. I did it to my '22 Mav and am going to do it this month to my '23 Mav. Lots of splash guards to remove but it is worth it. It stays soft, is self healing and most importantly it doesn't allow water to get stuck between it and the metal. I would never ever put Zeibart or any other rubberized undercoating that they keep adding on every year as part of their warranty. It can cause more rust problems than an uncoated vehicle because water can get between the metal and coating if it fails and the water has no place to go. There are a lot of repair shops around here that will refuse to work on a vehicle that has that stuff on it.
TheSEARCH
ford
Just had krowns done on my Hybrid Mav. I forgot the hood was aluminum which they sprayed the underside. i would have told them not to. Will it work i have no clue as its the first time I used this brand,. Buffalo NY so a lot of SALT on the roads. With tax $172. You have it done every year. I did drip the first day left it in the street that day BUT parked in driveway that night no drips i can see on cement,
