Rough/ Clunky Transmission
JSanchez
Jorge
Los Angeles
1996 Suburban C1500
Hello everyone,
Im trying to see if anyone else has been having any issues with your 8 speed transmission. Mine roughly started at about 4K miles. The shifts are somewhat rough/abrupt, clunky at slow speeds or when in traffic. Now at 10k miles it’s getting pretty annoying. I have no issues at higher speeds above 35-40mph. Initial acceleration feels as if tranny shifts through every single gear so it feels as if it’s hesitating. When in traffic, it’s constantly up shifting then down shifting when I let off the accelerator. Hope to hear your thoughts.
TC in MN
Minnesota
2022 Ford Mav XLT, CG, 2.0, AWD, Lux, tow, 360
I have 3k miles and have found the transmission in traffic goes thru the gears ok but lands in the highest gear way to early in the normal and eco drive modes; to the point of the engine lugging (can’t be good for a turbo engine).
Perhaps having 4K tow is a factor, cause when using the tow/haul drive mode, the transmission works great in traffic (albeit high revs).
As with you, on the highway there are no issues.
JSanchez
Jorge
Los Angeles
1996 Suburban C1500
I did think that the higher drive unit in the 4K tow would be some issue. I used to try slippery mode to retard some of the power and it helped for a while but it hasn’t done what it used to in some time. I would use slippery since I do not have eco due to the FX4.
The Weatherman
Dean
KY
I haven’t seen the same type of shifting issues, but I have noticed a less smooth transmission at lower speeds in the 4K version of the two Mavericks we have.
They are identical other than the 4K on mine. My wife’s drives silky smooth at lower speeds where as mine has noticeable shifts.
JSanchez
Jorge
Los Angeles
1996 Suburban C1500
Then that must be the culprit. Hopefully I notice what you’re stating in my upcoming Tremor.
FromAway
Maine
2022 Maverick Lariat FX4 4K Cactus Grey
No issues with mine accelerating. Even does great towing max payload. I have noticed it can get a little jerky downshifting around 2nd or 3rd gear sometimes.
AltoBAP
Jefferson
Metro Detroit
2020 Ford Fusion SE 2.0 AWD
Take it to the dealer. Sounds like potential valve body issues.
LtCasual
Paul
Minnesota, USA
2023 Maverick XLT
Can you check fluid level? I have seen some reports here on under and possibly overfilled transmissions from the factory.
L1a1
Lower Alabama
F-25O Super Duty
2023 EB AWD 4K tow package with 4600 miles and my truck does the herky jerky when shifting 1-4 at normal acceleration. It started this around the 3k mile mark, smooth as silk before this. I checked plugs, coils and the PCV valve as possibilities and decided that it is the transmission. Does this in all modes. No codes set. I haven't taken it in as the technicians we have now can't diagnose without a code. I am hoping i'll get a code or it implodes soon as this is very annoying.
Montana
I've seen a lot of reports on this on MTC. The 8 speed hunts worse than Elmer Fudd below 40 mph and I have the same issues with it as you do. Apparently there is a TSB on it but good luck getting it fixed. Some people in one thread I found reported their transmission being straight up replaced. I've had no luck with that and the parts the one dealer was going to order are on indefinite back order with no ETA, so I'm pushing for a straight up swap. This is what I found on it:
https://static.nhtsa.gov/odi/tsbs/2023/MC-10231021-0001.pdf
There are a couple other similar ones as well.
Ranch
Sacramento CA
2023 Marverick FX4 4K
The link you provided shows a very limited production problem. This customer satisfaction program is for 2022 Mavericks built from Oct 3 2022 through Oct 4 2022 with 29 total vehicles of all listed types in the affected population.
Not saying that there a not any problems with the 8F35 transmission.
Montana
Yea that is the only thing I personally found. But the TSB the dealer found mentions a lot more, I just can't find it.
brokenaxle
Justin
Calgary
2023 Ford Maverick, 2021 Jeep Gladiator
My 23 tremor lariat started shifting weird the day it hit 5,000km (3,100 miles), like someone flipped a switch on it. On up shifts it will shudder in the mid gears, 6-7 is fine but 7-8 at urban speeds it really shudders. Prior to this the motor/trans had good low torque response, very similar to my diesel Gladiator. On the highway it would hold 8th gear very good but now it seems like a modest head wind causes the transmission to start hunting gears like it has no torque from the motor. Another thing it started doing is down shifting two gears at urban speeds, this is a very jerky shift.
I tried the tow/haul setting and it helped the hunting for gears but this setting makes the transmission down shift hard when braking, like 3-3500rpm down shift. The city mpg is starting to get worse with all the extra shifting.
Ford Motor Company
Official Ford Account
Dearborn, mi
Hi there! I can look into your Maverick's concern on my end. To get started, could you please send a private message over with the name/location of your local Ford dealer and your Maverick's VIN?
