Has anyone noticed a restricted roll when going down a steep grade? Similar to if you had shifted to “low”. I’m guessing that it’s the difference between a regular automatic trans and the CVT?
It's probably your regenerative braking. I'll bet there's a difference between normal and economy mode.Has anyone noticed a restricted roll when going down a steep grade? Similar to if you had shifted to “low”. I’m guessing that it’s the difference between a regular automatic trans and the CVT?
ThisIt's probably your regenerative braking. I'll bet there's a difference between normal and economy mode.
When I first heard about the Maverick I liked everything about it except the CVT, didn't want that. Then, I read up a bit and found it was an eCVT. Very different. Clever and efficient.This
If OP tries the different modes they should see the difference. Also, hit the L button on the shifter dial for more regen. Really saves on brake pad wear going down hills or approaching a red light, while it increases battery charging.
And it's an eCVT, not a CVT. Huge difference.
Same here. Mav is basically a taller Prius with bigger motor and a bed.When I first heard about the Maverick I liked everything about it except the CVT, didn't want that. Then, I read up a bit and found it was an eCVT. Very different. Clever and efficient.
I then ordered a Maverick pronto.
That "restricted roll when going down a steep grade" is a positive for the hybrid as instead of wasting energy (and life of the brake pads) by using the brakes the energy is put back into the High Voltage battery.Has anyone noticed a restricted roll when going down a steep grade? Similar to if you had shifted to “low”. I’m guessing that it’s the difference between a regular automatic trans and the CVT?
That's the Grade Assist feature in action. See your manual and a video from Ford...Has anyone noticed a restricted roll when going down a steep grade? Similar to if you had shifted to “low”. I’m guessing that it’s the difference between a regular automatic trans and the CVT?
https://www.fordservicecontent.com/...ingEnabled=False&userMarket=USA&buildtype=webWHAT IS GRADE ASSIST
Provides additional grade braking with a combination of engine motoring and high-voltage battery charging to help maintain vehicle speed when descending a grade.
Worked in Fords research and development in Indianapolis for 28 years, I retired in 2008 so I got a heads up on anything that was coming in the future. Ford and Toyota co-developed the hybrid platform that they both use and that includes the ECVT. The transmission is basically bullet proof.This
Doesn't it have something like 2/3 less moving parts than and old-school automatic transmission?...Ford and Toyota co-developed the hybrid platform that they both use and that includes the ECVT. The transmission is basically bullet proof.
Exactly. I love the feature since it keeps the Mav hybrid from rolling unnecessarily on our steep TN hills, the opposite of our F-150. And also love seeing the power gauge down in the green during those times.If OP tries the different modes they should see the difference. Also, hit the L button on the shifter dial for more regen. Really saves on brake pad wear going down hills or approaching a red light, while it increases battery charging.
