Question about restrictions after getting a spray-in bed liner
James K
NY
Ask here rather than the shop doing the job, makes sense
Makes sense to me to get actual people that use the product over the place that sells the product. Why would you question that?
Halo9x
Hal
Abilene, TX
Maverick XLT 2023
Hello! First time truck owner so I have a (hopefully) quick question about the spray-in bed liner that I didn't find an answer to after searching. We are having the spray-in liner done this Friday (9/27). I am hoping to haul stuff, including a lawnmower, from my parent's house to my house (a 6 hour drive) the following weekend (10/6). Will this be possible? I'm not sure if there are any restrictions time-wise (for example, a curing time) that would make this unworkable. Anything else I should take into consideration? Thanks!
I have the SIBL that came from the factory. While it is tough, I think I would get a bed mat if you’re going to be loading/unloading heavy equipment that might scrape the lining. It never hurts to add extra protection.
Bigfoot7262
Wes
South Carolina
2024 Maverick XLT
I had a Line-x done in my last Toyota truck and was told 24 hours. For a push mower, I wouldn't think twice about loading it up.
Macadoo
San Diego
2023 XLT Maverick
Probably over kill but I put a DeeZee mat from Amazon on top of the spray liner. Adds padding for my knees and keeps cargo from sliding around. Easy to replace so you don’t have to worry about what you put on it. You can also pull it out to clean it. I didn’t want to go with just the mat because the spray liner helps protect the sides too.
JPinPA
Jay
Stewartstown PA
2024 Maverick XLT
Had a Rhino-Liner applied the week after I got my truck in May. As long as it is warm(ish) 24 - 48 hours and you'll be good for anything.
Of course you'll need to post obligatory pictures when it's done! ;)
zach57x
FL
2022 Maverick XLT
I would call your dealership.
Get the name of the shop.
Call the shop and get their recommendations.
I would add.
You may want to ask for a care and maintenance guide for your new spray-in bedliner.
The following is for Line-x
yours maybe different. It will give you a good general idea.
Good luck
The answer below provided by a Line-X Dealer
What about care/maintenance for the factory SIBL?
Redline
Upstate, NY
I also have the DeeZee rubber bed mat on top of my SIBL. I like how they put nubs on the bottom side so it doesn't sit flat on the bed which allows airflow to get under the mat and prevent moisture buildup. It was around $120 on Amazon. Totally worth it, imo.
